Posts: 452 from 2006/11/16
Goodday to you all morphos users.
Is there a way to cut a .avi file in two with mencoder?
Or another way to shrink it's size to get it through the email?
It's about 20MB now too big for mailbox.
It is a video taken with a digital camera.
Mplayer plays it with ffmjpeg video codec.
It has a video bitrate off 2449 kbps
resolution is 320 x 240
frames per second 30
aspect 0.0
audio is ulaw audio codec
audio bitrate is 88 kbps
audiosamples 11 KHz,mono
I downloaded the mengui tried different settings for example tried rotating but saved file (after pressing encode )is not rotated.
And there is a crop function maybe this is usefull to shrink the video's format?
But is has four parameters: width height x y ?
But setting some numbers doesnt change the output file.
