ICQ and MorphOS
    clr666
    Posts: 86 from 2008/7/8
    Anybody setting up ICQ transport in Jabberwocky?
    I cannot find any howto. Maybe it is impossible?
    _______________
    wintel free
  • »02.08.09 - 05:01
    MarK
    Posts: 641 from 2004/1/25
    well, it works pretty well, although it's not very flexible and comfortable. but... you need afaik, a registered jabberwocky account to do so...
    bye, MarK.
  • »02.08.09 - 09:22
    clr666
    Nice to hear this. Can you create a mini-howto?
    _______________
    wintel free
  • »02.08.09 - 10:11
    Posts: 12530 from 2003/5/22
    No, you just need to register with a Jabber/XMPP host of your choice. And if it's one that doesn't provide the needed transport, you can simply register with the transport(s) provided by another Jabber/XMPP host.
  • »02.08.09 - 11:07
    clr666
    Ok, issue solved. All i just need - is working ICQ transport server, then add in Windows -> Agents
    _______________
    wintel free
  • »02.08.09 - 14:29
