SimpleMail question
    CountRaven
    Posts: 566 from 2007/12/10
    It is me again :)
    Well I am trying this nice email application, setting up an account adding all the pop3 stuff, I am saving the prefs. But the account seems not to be activated in the program. I take the same 0 mail notification in all the incoming, sent etc folders, every time I start the program. The add/get button seems not to do anything.
    The same account with the same pop3 parameters works fine in YAM.
    Any ideas?
  • »22.07.09 - 09:52
    Jambalah
    Posts: 820 from 2008/3/30
    Wich version do you use? Seems that 0.32 is much more stable than the 0.33.
    But I didn't tested that (I'm using the 0.32) and I wouldn't be wrong...
    Moreover there are two version of SM 0.33: if you are using this, be sure that is the "simplemail-0.33-morphos.lha" and not the "os3".
    This one start but I'm not sure that works fine.
    Last minute:
    Tested V0.33 on the fly and it seems all work fine.
    Pressing add/get works without problem.
    But its not a real test...... sorry...
    Last second:
    testede v0.33
    Account working, sending and receiving mails work too. No crash or other issue.
    So, how to help?!
    Maybe the simplemail.guide could do? The "requirements" session it's interesting...
    Try to see if something that simplemail needs is missing.
    [ Edited by Jambalah on 2009/7/22 16:19 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »22.07.09 - 11:57
  • HAK
    Posts: 227 from 2003/2/24
    Since we're talking about SimpleMail 0.33.
    Anyone here who uses it and has problems with filtering?
    Automatic filtering doesn't work here anymore since I changed from 0.32 to 0.33 and I have to activate it manually every time I see relevant mails in my inbound directory.
    Bye HAK
  • »22.07.09 - 20:23
    CountRaven
    @Jambalah
    Oh thanks for the tests!!!
    I will get back to you with version info.
    I will also download the correct 0.33 version you are suggesting.
    And I will try again!
    Will keep you posted!!!
  • »22.07.09 - 23:46
    Henes
    Posts: 507 from 2003/6/14
    Sounds like an amissl issue.
  • »23.07.09 - 07:08
    Posts: 108 from 2005/4/3
    SimpleMail 0.33, i use filtering, it goes OK. I setup it with version 0.33.
    Offcourse the MorphOS version of SimpleMail i use.
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »24.07.09 - 05:37
