Problem with ANR, nothing in shoutcast search
    Brumiga
    Posts: 277 from 2004/4/3
    Hello,
    There is a problem with ANR. In the shoutcast window i click on "GO" button, there is a scan but no stream appears in the columns below. I tried with snoopdos to see where it scans but without results.
    Does amigazeux team have an explanation about this problem ? Can we expect a workaround, and when ?
    Brumiga
    [ Edited by Brumiga on 2008/9/20 15:01 ]
  • »20.09.08 - 12:00
    Framiga
    Posts: 363 from 2003/7/11
    shoutcast server change
    post #5 by ZeroG
    [ Edited by Framiga on 2008/9/20 15:38 ]
  • »20.09.08 - 12:35
    Cego
    Posts: 738 from 2006/5/27
    open your prefs and go to the shoutcast tab.
    and insert following IP:
    207.200.98.25
    now it should work again.
  • »20.09.08 - 12:47
    AyoS
    Posts: 410 from 2003/8/13
    Thanks!!! until I searched I thought it was
    Just me...LOL
  • »29.09.08 - 21:15
    Get27
    Posts: 90 from 2004/8/23
    thanks. I tried to find a soluce since few days
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »30.09.08 - 20:15
  • rms
    rms
    Posts: 606 from 2004/11/27
    207.200.98.25
    Hi all,
    it seems that there is again the problem that nothing gehts shown
    when doing a shoutcast search...
    Has anyone the same?
    Any solution?
    Regards
    Christoph
  • »08.12.08 - 05:57
    Kamul
    Posts: 121 from 2004/6/9
    Here works without any problems.
  • »08.12.08 - 15:23
  • rms
    rms
    Hi all,
    it works again this morning. Very sorry I posted this message to quickly, next time I will wait some more.
    Regards
    Christoph
  • »09.12.08 - 05:06
  • rms
    rms
    Hi all,
    since several days now I'm not able to listen to any Shoutcast with Aminetradio anymore :-(
    I have under Shoutsearch, proxy: http://207.200.98.25
    and searching is ok is well, at least 50 stations get listed but then when I click twice on one of them, Aminetradio starts to fill the buffer more or less up to 45% and then instead to play in goes to stop. I tried about 20 different stations but all with the same result, it doesn't play anything.
    Does anyone have the same? Any idea why this problem or how to solve it?
    BTW, I didn't install anything special, no games at all...
    Thnaks in advance for help.
    Regards
    Christoph
  • »08.07.09 - 06:54
    igracki
    Posts: 469 from 2003/2/24
    Here it works!
    I have "http://classic.shoutcast.com" as proxy in the shoutcast search tab.
  • »08.07.09 - 07:44
  • rms
    rms
    @ igracki
    really strange... neither with your URL, neither with my URL it will play! ANR searches the stations, they get listed but when hitting play, as I said already, it goes up to about 43% and then stops...
    AFAIR I updated the reggae classes lately, so I will check if that could be the cause...
    If anyone has any further ideas, please let me know.
    Regards
    Christoph
  • »09.07.09 - 02:55
    igracki
    Do local mp3 songs get played?
    I had a similar problem, when I had an old ptplay.library installed.
    Then I installed v2.6 (23.03.07) and the problem was gone;)
  • »09.07.09 - 09:44
  • rms
    rms
    Yes mp3 songs are played without any problems!
    I have the same ptplay.library installed as you have but it still doesn't work. I also tried to replace the ptplay.library
    with the one which came with ANR v4 but it still doesn't work.
    Strange....
  • »09.07.09 - 13:59
