Scube & Lucy
    Posts: 423 from 2005/4/9
    i've got some problems with these great new toys, perhaps others too.
    problem with scube is, that i want to start it at boot, therefore i've put it in wbstartup, but it couldnt find the gfx this way.
    ok, i wrote a line in user-startup (run >nil: path:scube).
    it works now but when it enter the cube mode, instead of the background pic
    theres some garbage made from the screen behind and while the cube is rotating,
    it leaves its mark all the time - all previous frames can be seen at once.
    when i deactivate it from exchange then start it from ambient it works fine.
    i even added a line to user startup - path "scube's path" ADD, but it didnt solve the problem:)
    with lucy i've got only a few minor problems: first and most important, that the panel is also transparent,
    guess coz its inactive, even if i set the "ignore backdrop windows - mabye panel is not...)
    second problem, nor "window under mouse pointar and active window..." nor "auto-activate window" options doesnt seem to work.
    i set them but no effect.
    to write something positive too, i must tell that i am really impressed by these softwares,
    the speed and smoothness of the cube is incredible, its a lot faster then the cube in compiz/linux (athlon2700+, radeon 9800)!
    lucy is got me with "her" nice gui and the one-click window acrivation is really handy!
    thanks guys!
    [ Edited by sadddam on 2008/7/3 1:38 ]
    zx.spectrum@3.5
  • »02.07.08 - 22:35
    Jambalah
    Posts: 820 from 2008/3/30
    I did it in this way:
    I took an icon of an already existent program. A project icon not a tool icon. I renamed "Scube_MOS" and changed the default tool with directory and drawers in wich scube is (ie:Morphos:Tools/scube/scube). Put it in WBstartup and it works without any problems. I didn't modified the user-startup in this way. Little tricky, but I didn't want to fight against icon... and so... :-)
    Lucy: like all womens do, "she" does on your own! I changed configuration in different ways.. But it's the same: panel is transparent and the pointer settings don't work. Wow! What a woman!!! ;-)
    Enjoy
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »03.07.08 - 06:40
    Posts: 1087 from 2003/3/24
    I have the same Problem with the Panel it is Transparent but sometimes not. wired
  • »03.07.08 - 10:54
    Jeckel
    Posts: 133 from 2007/3/11
    Here Lucy works only for the Ambient screen windows.
  • »03.07.08 - 13:46
    its normal, as written in the readme, lucy works only on those screens where from it has been opened - at the moment (maybe this will change in the future).
    zx.spectrum@3.5
  • »03.07.08 - 13:55
    Jeckel
    sadddam wrote:
    its normal, as written in the readme [...]
    Hmmm, I had no readme with Lucy... oh archive has been updated ! Let's have a look at the new version. :-)
  • »03.07.08 - 14:07
    @jambalah: thanks mate! that one worked!
    but what did you mean at the other thread by "try the mouse" or something like that?
    i cannot activate the cube with mouse only, just with crtl+tab.
    lucy has updated, auto-activation and mousepointer stuff working now!
    great, thanks guys!
    panel is still transparent, guess its not a bug but a more complicated issue...
    [ Edited by sadddam on 2008/7/4 1:46 ]
    zx.spectrum@3.5
  • »03.07.08 - 21:52
    Jambalah
    @ sadddam:
    glad It was helpful! :)
    In the other 3d, I meant mouse used to move the whole cube. That's great!
    Or perhaps...no, no I'm sure: It's MOS Team a great work!
    Pegasos II 1 ghz
  • »04.07.08 - 02:49
    amif1team
    Posts: 16 from 2007/6/30
    Please give my links to Scube & Lucy (sorry for my bad english) :( I dont find link to Scube & Lucy :(
    -=\ amif1team /=- team Dogma
    http://www.dogma.org.ru
    http://www.amiga.org.ru
  • »04.07.08 - 04:37
    amif1team:
    scube: http://kiero.binaryriot.org/scube.lha
    lucy: http://amigazeux.org/
    zx.spectrum@3.5
  • »04.07.08 - 06:18
    i think i've found a bug in scbube: when more than 2 screens are opened, ctrl+tab jumps between only two of them,
    when a screen selected with mouse, it not jumps into the focused screen but a completly different one...
    when more than 4 screen are opened you cannot select the screens on top and below, not with ctrl+tab nor with mouse.
    lucy: the menus acting weird when lucy is running.
    zx.spectrum@3.5
  • »04.07.08 - 13:02
    kriz
    Posts: 314 from 2005/10/18
    SCube is cool, but yeah i have the same problem as Saddam here...
  • »23.08.08 - 09:11
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    I experience 2 problems when using SCube:
    1) I opend 3 programs (and Ambient is open) on seperate screens, one is "Designer", then "PageStream4" and "Blender". Now when I cycle through the screens with ctrl+tab and PageStream4 is selected then the screen jumps all the time to another one except PageStream4. The others are ok, I mean if I select either Blender, or designer or Ambient it works.
    I noticed the same problem as with PageStream4 with BME.
    2) When I cycle through the screens there is often, but not every time a strange pattern showing up during the cycling in the background. To better explain what I want to explain, I made a small video (2.5 MB) which can be downloaded her:
    http://www.rmsvideo.ch/public_rms/morphos/scube_320x240.avi
    For info, to better show the problem I made all the images in the skybox drawer black to acheive a black background.
    Could these be bugs? Does anyone else have these problems?
    Regards
    Christoph
  • »08.10.08 - 12:33
    The first Problem you discribe is happening to me and others too.
    The second Problem is maybe releated to your GFX Mem or GFX Board.
    Maybe your Card is about to running out of GFX Mem.
    What resolution are you using and how much GFX Mem did you Card have?
  • »08.10.08 - 13:36
  • rms
    rms
    @ ThePlayer
    Ah, ok, then perhaps this problem will be fixed for a next version.
    Well, I use an Radeon9000Pro with 128 MB of RAM and the resolution is 1600x1200x24. Connected via DVI on an Eizo CG21.
    I have a newer card, an Radeon9250Pro with 256MB of RAM but unfortunately I can't connect the Monitor to the DVI port on this card with a resolution of 1600x1200x24. Lower resolutions seem to work...
    Perhaps my GraphicCard's DDR Memory of the 9000Pro has a problem then?
  • »09.10.08 - 10:35
  • rms
    rms
    I made a serial log right after a reboot which shows that there "R200: Unable to istall texture"
    The log can be found here:
    http://www.rmsvideo.ch/public_rms/morphos/scube_serial_log.txt
    Any idea what that could be?
    Regards
    Christoph
  • »10.10.08 - 05:43
    Posts: 2217 from 2003/2/24
    Are you sure your working dir is on the scube's dir? For example if you run scube from shell when you're on some other dir, then it can't find the textures. You must cd to scube's dir first.
  • »10.10.08 - 07:51
  • rms
    rms
    @ jPV
    I don't know what exactely you mean but I'm shure that SCube gets started via the WBStartub and it finds all the textures it needs!
    Here is a Snoopium log when I start SCube:
    [1] [SCube] [ChangeDir] [System:Utilities/SCube] [] []
    [2] [SCube] [Open] [CON:10/10/320/80/SCube/AUTO/CLOSE/WAIT] [Modify] [OK]
    [3] [SCube] [Open] [*] [Modify] [OK]
    [4] [SCube] [Open] [skybox/front.jpg] [Read] [OK]
    [5] [SCube] [Open] [skybox/back.jpg] [Read] [OK]
    [6] [SCube] [Open] [skybox/left.jpg] [Read] [OK]
    [7] [SCube] [Open] [skybox/right.jpg] [Read] [OK]
    [8] [SCube] [Open] [skybox/up.jpg] [Read] [OK]
    [9] [SCube] [Open] [skybox/down.jpg] [Read] [OK]
    Regards
    Christoph
  • »10.10.08 - 10:26
    dake
    Posts: 204 from 2007/9/14
    kiero has released a new version of scube.
    Thx kiero.
  • »28.06.09 - 14:20
    dIGIMAN
    Posts: 273 from 2005/11/7
    Thx kiero.
    Did somebody notice any changes?
  • »29.06.09 - 08:51
    Wishmaster
    Posts: 342 from 2003/6/29
    The new Scube version is selecting the correct Screens. No Problems anymore.
    But how do you get transparent Panels?
    Pegasos PPC
  • »29.06.09 - 10:53
    SoundSquare
    Posts: 1214 from 2004/12/1
    in the panel prefs, choose "always on front" and your panel will be solid again.
    the contrary....
  • »29.06.09 - 11:00
    dake
    @dIGIMAN
    Earlier you could only switch between two screens, now it work to switch between four screens.
  • »29.06.09 - 13:09
