Feebles Files sound and slow machine.
    Robert
    Posts: 331 from 2003/5/12
    Does anyone know how to redirect the sound in the feeble files to a
    PCI card? when I play the game I can here the sound very faintly from
    the case speaker but not my SB card. PSA outputs to it fine and I
    tried changing system settings back to Pegasos 16 bit stereo but
    normal sound was still being output via the SB, while Feeble Files
    still only outputs to the case speaker. (I think.)
    Unrelated to this I tried to view an mpeg file with mplayer and the
    machine froze. After several reboots and a couple of extended switch
    offs, it is still behaving really sluggish. Miami now takes several
    seconds to load and simplemail even longer. Any idea what could be
    causing this. Booting takes longer now too.
    Cheers,
    Robert.
    Robert.
  • »13.10.03 - 20:42
    tokai
    Posts: 1289 from 2003/2/25
    slow machine problem:
    maybe you use a ffs partition... and this partitions is now not validated because the crash and has started autovalidation. Check if you have permanent hd accesses after boot. if so then only need to wait until it's done. can need very long on big partitions. :-)
  • »14.10.03 - 21:45
