NetStack: how to deactivate/activate this.
    Jambalah
    Posts: 820 from 2008/3/30
    Is it possible deactivate NetStack? And if so, how?
    Then can you perform the inverse procedure?
    I searched in the forums but I found nothing (hoping I didn't miss something.... :-) )
    Thanks in advance.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »04.06.09 - 12:44
    Posts: 1521 from 2003/2/24
    Send CTRL-C to NetStack. This can be done from Scout for example. You can restart stack by executing S:Network-Startup.
  • »04.06.09 - 13:22
    Jambalah
    Thanks very much!
    Useful help ;-)
    Pegasos II 1 ghz
  • »04.06.09 - 15:33
    jcmarcos
    Posts: 1178 from 2003/3/13
    Is that the same thing one can do with the "break" shell command?
  • »05.06.09 - 04:47
    Piru
    Posts: 622 from 2003/2/24
    Yes. Break can be used to send the CTRL-C signal to owner of a named message port, too. This is especially handy with the NetStack/AmiTCP as it can be used to terminate it easily:
    Break PORT AMITCP ; terminates both AmiTPC/IP and Netstack
    or
    Break PORT NETSTACK ; only terminates Netstack
    All this in combination with WaitForPort can be used to create nice scripts for swapping between different TCP/IP stacks for example. WaitForPort DISAPPEAR/S option can be used to wait the port to go away (useful if you need to know when it is safe to launch the new TCP stack).
  • »05.06.09 - 15:56
    jcmarcos
    @Piru:
    What a nice operating system (sorry, couldn't resist). Well, actually, its applications, that are well designed, and actually listen and attend to "break" commands.
    I didn't lnow about the "port" option, I guess I stopped learning about AmigaDOS back in 2.x age...
    About "waitforport", is it related to ARexx ports only? Because, when you explained "break", you were reffering to generic message ports, right?
    Finally, will we have a native MorphOS ARexx interpreter anytime soon? I guess there's nothing bad in reusing the original ARexx library, aside from the fact that it must be "stolen" (ahem) from Commodore's original siystem. But I also understand that it's not an urgent or specially interesting development, not to mention its difficulty.
    In my case, I have to admit, I had to download an unlicensed AmigaOS from the net, just to extract that file alone. I don't have a real Amiga any longer, in order to read my original AmigaOS disks.
  • »08.06.09 - 05:08
    CISC
    Posts: 619 from 2005/8/27
    WaitForPort works for any named port.
    Sadly this is not very likely as I have next-to-no time for MorphOS development these days (way too much C# development at work). I might allocate some time for MorphOS development during the summer vacation, but this is best spent concentrating on other urgent matters aside from ARexx... :(
    - CISC
  • »08.06.09 - 05:19
