weather programs
    xyphoid
    Posts: 870 from 2008/7/11
    I can't seem to get any of them going on Efika (wet wetter weather) wet accesses then does nothing, wetter complains
    about not being able to creat a mui application, and weather just sits their (probably needs mosmediapack12 or something, but my searches came up with broken links) Any suggestion, Do we even have any dash board like applications like MacOSX?(scores, news,entertainment,weather)
    Posted with OWB 1.2
    [ Edited by xyphoid on 2009/4/26 23:59 ]
  • »27.04.09 - 01:57
    Krashan
    Posts: 1107 from 2003/6/11
    About Weather by Marcin Kwiatkowski - so called "MOSMediaPack" is just Reggae (see my sig), which is now a standard part of MorphOS. Too bad Reggae API changed sligthly a bit since 2004 and that is probably why it does not work. I can fix it assuming I manage to get sources from Marcin. I will try to contact him.
  • »27.04.09 - 03:45
    xyphoid
    ok, I see that would be great!
  • »27.04.09 - 13:09
    Motosampy
    Posts: 199 from 2004/8/14
    Wetter (v1.19) works fine here on MOS2.0 (PegII).
    Maybe some mui library in your system is causing your problem ...
    Correction to my OS version: 2.2 :)
    [ Edited by Motosampy on 2009/4/28 19:26 ]
  • »27.04.09 - 15:00
    Posts: 2213 from 2003/2/24
    Wetter 1.19 works fine here too. With MorphOS2.2 and Peg1.
    You can make it look very custom... Here is an example of it in my toolbar at the bottom of the Ambient screen :)
  • »27.04.09 - 18:08
    xyphoid
    @jPV That is nice!! Ok So I've got to figure out what the mui issue is huuh?
  • »27.04.09 - 23:35
    Check with Snoopium if it's missing some MUI library.
  • »28.04.09 - 06:59
    Wishmaster
    Posts: 342 from 2003/6/29
    I prefer Wetter NG.
    Pegasos PPC
  • »28.04.09 - 09:38
