avi to asf
    xyphoid
    Posts: 870 from 2008/7/11
    before I search for pc solution, is there a program which converts avi to .asf video format on our system(s)? If not feel free to list the pc solutions.
    cheers!
  • »15.03.09 - 15:50
    Golem
    Posts: 766 from 2003/2/28
    Mencoder should be able to output asf.
  • »15.03.09 - 17:11
    xyphoid
    thanks, as I feared the process would be command based, I found a gui on aminet, but saw no options for converting the file. I tried a readme , but didn't see one in gmplayer, which has mencoder . I'm afraid I need assistance with the commands
  • »15.03.09 - 20:24
    xyphoid
    any further assistance on this before I move on?
  • »17.03.09 - 22:57
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Well, the mencoder documentation is really quite exhaustive about all this.
    Anyway,
    mencoder yourfile -o output.asf -ovc lavc oac mp3lame -lavcopts vcodec=msmpeg4 -of lavf -lavfopts format=asf
    You can also use vcodec=wmv2. You could select much more if wanted (video bitrate, audio bitrate, frequency, ....)
  • »17.03.09 - 23:37
    xyphoid
    thanks as always Fab
  • »18.03.09 - 22:38
