AmiNetRadio sliders font
    r-tea
    Posts: 315 from 2005/3/27
    Hi all!
    I use ANR with Classic.gui (the famous green one) and recently I wanted to change font of those three sliders on the bottom of main window. But I can't.
    For the first time It was the most obvious for me to change Button -> Slider in MUI prefs - woun't work. Then I started to try to change all the others elements in MUI prefs I suspect to handle those three sliders, but I didn't encounter anything reacting.
    Is this font changeable at all?
  • »14.02.09 - 13:43
    XzIt
    Posts: 250 from 2005/1/19
    Not tried this, but think you need to edit the skin itself?
    If it's button on the player itself and not on the windows, playlist, shoutcast, etc.
    X
  • »16.02.09 - 07:14
    r-tea
    There is no possibility to edit font of that sliders in skin prefs.
    I think I have too old version of MUI4  :-)
    Thanks!
    [ Edited by r-tea on 2009/2/17 12:56 ]
  • »17.02.09 - 09:55
