blanker problems
    Posts: 423 from 2005/4/9
    I have a problem which i've reported to #morphos a few times before.
    Blanker is not activate on Ambient screen.
    It works on every other screen.
    I have Blanker set to 1min and DPMS-Off to 3 mins.
    On Ambient screen Blanker is not activated even after 5-10-15 mins,
    if i switch to another screen Blanker will start after 1 min as it should.
    It happens randomly, even just after a boot or sometimes it
    works for a few times, but then Blanker wont activate on Ambient
    screen until the next boot. It doesnt matter what sw running
    or been ran before.
    Im using "Solar Winds" blanker module but i've tried other modules as well (with same results).
    Another problem with my favorite blanker, Flurry: it works fine for preview but
    when it is in action its broken - screen looks like as multiscan on pal tv. The system doesnt crash everything is ok,
    and if i press preview again Flurry will be displayed fine. Every other
    blanker works both in preview and in action (except on Amibent screen).
    Has anyone got similar problems?
    [ Edited by sadddam on 2009/1/23 17:44 ]
    [ Edited by sadddam on 2009/1/23 17:45 ]
    zx.spectrum@3.5
  • »23.01.09 - 14:43
    Jambalah
    Posts: 820 from 2008/3/30
    Hi sadddam!
    Armed with curiosity and patience I tested all the blankers and here they are:
    Aswarm: working
    Atlantis: working
    BlockTube: not working. Tested in different screenmodes gave the same result.
    Boing: working
    Butterflies: working
    Coor: working
    CosmiqueVoyage: working
    Feathers: working
    Flame: working
    Flurry: not working. Testede in different screenmodes gave the same result
    Fractal3D: not working, even in different screenmodes.
    FuzzyFlakes: working
    Galaxia: working
    Gears: not working. The same in different screenmodes.
    LMatrix: working
    Hop Along: working
    Luppa: working
    Maze: working
    Moire: working
    Morph3D: not working. Tested in many screenmodes with no succes
    Nowhere: working
    PicView: working
    Pig Invasion: working
    Plasma: working
    QixLine: working
    Solar Winds: working
    Spikeball: not working, whatever screenmode you use
    Sproinger: working
    The Blots: working
    Toaster: working
    I'm using a ATI Radeon 9250 (but MorphOS:Utilities/GraphicBoard says it's a 9200p) with 128 MB.
    I confirn that all the blankers work in preview mode but some of tem (those above) don't in "real" mode. I setted blanker time at 1 minute and after that time blanker started.
    I tried different screenmodes only with blankers that didn't work because all the others started from Ambient screen with no problems.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »24.01.09 - 13:19
    Posts: 3297 from 2003/3/5
    @saddam: paste your blanker.conf please
  • »25.01.09 - 09:42
    oops, soory, havent noticed your request till now:)
    here it is:
    Name="solarwinds.btd" Type=0x0 Width=1600 Height=1200 Monitor=0x0 BlankTime=600 DPMSSuspendTime=0 DPMSStandbyTime=0 DPMSOnTime=3000 EventFlags=0x1F OffFlags=0xF
    Blanker="solarwinds.btd"
    Tag=0x804254A8 Value=0x0
    zx.spectrum@3.5
  • »04.02.09 - 14:14
    ok, problem found , been working on it.
    fixed blankers will be included in the next release.
    thx jambalah for the test btw:)
    zx.spectrum@3.5
  • »12.02.09 - 11:27
