MPlayer vs VLC Player?
    Solo_Kazuki
    Posts: 186 from 2006/7/23
    Yesterday i downloaded one movie, which is playable only with VLC Player.
    Moreover, it is played without any error (e.g. messy frames or noise), so video is ok (or at least VLC Player will repair it on-fly).
    http://www.ehoza.com/v4/forum/asian-movies/31726-yo-yo-girl-cop.html
    What's wrong? Are there some codecs playable with VLC Player, but doesn't with MPlayer?
  • »21.01.09 - 18:03
    Posts: 918 from 2004/1/24
    Must be MPlayer's build in anti-crap algorithms
    /me runs ;-)
  • »21.01.09 - 18:12
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I just downloaded the first 10 Megs, and didn't see anything wrong with mplayer. If there are artefacts later, well, maybe it's just the source being crappy. Then players can handle errors differently.
  • »21.01.09 - 19:18
    Solo_Kazuki
    And how to repair errors? I'm sure that video and audio streams are intact (checked), so problem is probably with "header'n'stuff". And MEncoder doesn't recognise filetype (as same as Ambient).
  • »23.01.09 - 14:53
    Henes
    Posts: 507 from 2003/6/14
    The whole movie plays fine with MPlayer. Your problem must be elsewhere...
  • »23.01.09 - 17:11
    Solo_Kazuki
    Damn... post is edited already, there's available decent quality (video is very blurry and misty and very pixelised in action scenes) version with english hardsubs, right?
    So i'll try to find it anywhere else...
    I'll also check this current version, to be sure ;)
    Edit: Ok, i found this version
    http://rapidshare.com/files/64623757/Yo_Yo_Girl_Cop.avi.0
    http://rapidshare.com/files/64635438/Yo_Yo_Girl_Cop.avi.1
    http://rapidshare.com/files/64646396/Yo_Yo_Girl_Cop.avi.2
    http://rapidshare.com/files/64657741/Yo_Yo_Girl_Cop.avi.3
    http://rapidshare.com/files/64685998/Yo_Yo_Girl_Cop.avi.4
    http://rapidshare.com/files/64696900/Yo_Yo_Girl_Cop.avi.5
    http://rapidshare.com/files/64708000/Yo_Yo_Girl_Cop.avi.6
    http://rapidshare.com/files/64711631/Yo_Yo_Girl_Cop.avi.7
    And try now this version ;)
    Edit 2: ok, i found out what was wrong. This AVI have some weird header before real AVI header. So to "repair" this movie you must cut out first 64 bytes of full file.
    And btw: here's english SRT for this movie
    http://napisy.info/napisy_info_86524.zip
    [ Edited by Solo_Kazuki on 2009/1/24 5:05 ]
  • »23.01.09 - 17:39
    Kaczus
    Posts: 199 from 2003/9/6
    I try to play vcd using new version mplayer, but I don't know, how tio do it...
    mplayer vcd://2 -cdrom-device ide.device:2
    doesn't work.
    Using 0.91 version mplayer and frogger it works, but problem is with blanker :)
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »24.01.09 - 20:14
  • Fab
    Fab
    VCD isn't enabled in current releases. It has changed quite a bit since 0.91, and since i don't have any VCD at hand, i wouldn't be able to test it. So 0.91 is your friend for these. :)
  • »24.01.09 - 21:39
    Kaczus
    If You want, I can find needless vcd and send You.
  • »26.01.09 - 13:59
