MetalWeb 4
    Simon
    Posts: 809 from 2008/7/6
    Does anyone have metalweb running under MorphOS 2.2 ?
    I always get "can not build application" . I did copy all the MUIclasses except for the ones I had newer versions for. Could this be the problem, newer versions of muiclasses that aren't 100% backwardcompatible ?
  • »23.01.09 - 21:04
    Posts: 3336 from 2003/3/5
    It's highly unlikely that our classes aren't backwards compatible. Did you try to check the Snoopium log to see what class/library fails to open?
  • »25.01.09 - 09:37
    Simon
    I always forget about Snoopium ... got it running now, it was missing muigfx.library
    thank you
  • »25.01.09 - 12:17
    CountRaven
    Posts: 566 from 2007/12/10
    what is this app for?
  • »25.01.09 - 18:04
    Simon
    i think it's the only wysiwyg html editor there is for Amiga... here is the website. It is or was (?) endorsed by vaporware.
    http://www.vapor.com/metalweb/
  • »25.01.09 - 18:34
