Creating an swf animation with MorphOS
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    I need to create an swf animation, if possible under MorphOS. I would like transform e. g. an
    avi video to swf.
    Has anyone experience with this and could help me? Are there any tools to do this?
    Any help will be very much welcome.
    Regards
    Christoph
  • »15.01.09 - 17:31
    roschmyr
    Posts: 211 from 2003/2/20
    @rms
    try mencoder
    mencoder -ofps 15 -of lavf -oac mp3lame -lameopts abr:br=22 -srate 22050 -ovc lavc -lavcopts vcodec=flv:keyint=50:vbitrate=80:mbd=2:mv0:trell:v4mv:cbp:last_pred=3 -vf scale=320:240 "inputfile" -o "outputfile"
  • »15.01.09 - 18:06
  • rms
    rms
    @ roschmyr
    Thanks for help! I tried your solution but I only get audio, no video, the shell output is:
    ** MUXER_LAVF *****************************************************************
    REMEMBER: MEncoder's libavformat muxing is presently broken and can generate
    INCORRECT files in the presence of B-frames. Moreover, due to bugs MPlayer
    will play these INCORRECT files as if nothing were wrong!
    OK, exit.
    and then it skipps the frames :-( The result is a file with only audio.
    Any idea?
  • »15.01.09 - 19:05
    roschmyr
    i tried an avi and it works(tm) ;)
    do you have the latest version installed http://fabportnawak.free.fr/mplayer/
  • »15.01.09 - 19:13
  • rms
    rms
    Yes it seems that I do have the latest version, it's the one from the MPlayer-1.0-svn-2008.12.15.lha
    archive which states: MPlayer 1.0 (08.12.2008) [SVN:28114]
    Do you have another version?
    Do you also get the "MUXER_LAVF" shell output?
    Did you try to play the file with FlashPlayer http://aminet.net/gfx/show/FlashPlayer_mos.lha
    or MPlayer?
    With Flashplayer I only can hear the sound but there are on video.
    I need to create a swf which must be playable by a standard swf player on PC. The swf is used for
    an internal video channel.
    I'v got an example what I need to create which is playable by Flashplayer and flash movie info is:
    - frame size is 728 x 576
    - frame rate is 25 / sec.
    - Flash Format Version 6
  • »16.01.09 - 05:38
    Jambalah
    Posts: 820 from 2008/3/30
    I encoded a mpg video to flv using MenGUI
    and all works fine. I used an old mencoder version and the latest without any problem.
    To see the flv video I used MPlayer itself.
    I even tried to encode a swf video but the resulting file couldn't be read neither with MPlayer nor with FlashPlayerMOS.
    I didn't try any parameters configuration... I'm not so able, sorry... So I suppose it's not a mencoder problem..
    But if you need a flv video MenGUI goes great!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »16.01.09 - 06:12
  • rms
    rms
    This IS the problem! MPlayer plays it ok but Flashplayer doesn't! I need a file which
    plays everywhere without problems.
    And yes I also tried an mpg video as well as avi, both encode ok but seem not to be playable
    by the Flashplayer.
    I also tried older software, like swftools-0.4.4 and his "avi2swf" but it seems not to work
    under MorphOS...
    Any other idea?
  • »17.01.09 - 06:58
