(SOLVED) using a HFS partition with Basilisk II
    Posts: 1362 from 2004/2/8
    I've been trying to use a HFS partition from a hard disk taken from my classic system with Basilisk II. I connected it to my Efika through a IDE->USB cable.
    The disk works just fine and I can see all the partitions on Ambient. All of them except for the HFS one. I guess that's OK because I need this partition only for emulation, but - since it's not seen - Basilisk won't see it too.
  • »11.01.09 - 06:27
    It turned out that MorphOS 2.2 tool rawdisk: is my best friend.
    All you have to do is select an ordinary file-partition in Basilisk prefs and then put something like
    rawdisk:devices/usbscsi.device/0/RDB/partition05
    as a path.
    (note that the numbers start from 00, so that was the sixth partition on my old HD).
    Thx zukow :)
  • »11.01.09 - 19:38
    Thanks for the info for the rest of us.  8-)
  • »12.01.09 - 01:18
