E-UAE and WHDLoad
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hey dudes,
    i guess a few of you noticed already that WHDLoad simply doesnt work
    like it should in EUAE
    In the most games you are not able to use any savegame functions.
    Mostly it quits with an AmigaDos Error saying that the memory
    is full or either it just claims that it saved, but when u
    quit and restart, u see nothing was saved.
    Running the games without EUAE lets them work fine.
    The problem is, that alot games dont run without WHDLoad.
    Somebody every found a solution for that or even
    fixed the source itself?
    This is what i got as a response on the WHDLoad ML
    > > You missed it. Its not a problem of WHDLoad but of eUAE.
    > > Richard knows about it and as soon (maybe) a new version is out this
    > > problem will be addressed ... in fact the SVN version has a fix already,
    > > but Richard never released a new build for Amiga(OS4) and he doesn't
    > > answer eMails for some months know :-/
    > Ok, sorry for that. And even if it is a EUAE Problem, isnt there a
    > way to bypass it from whdload side in the meantime? WHDLoad must do
    > something diffrent then the other save routines as without whdload
    > it works but this makes it unplayble on MorphOS or OS4 Setups that
    > require EUAE for certain Games. I would really like to lunch and
    > play games from ambient, if possible somehow.
    I have no idea what the reason for this problem is. And therefore also
    no idea what could be changed in WHDLoad.
    Because it's known to be a problem in euae I also don't want to spend
    any time on looking for that.
    [ Edited by dIGIMAN on 2008/12/26 16:54 ]
  • »26.12.08 - 13:53
    analogkid
    Posts: 709 from 2004/11/3
    Maybe it's a problem related to the device having more space than 4 GB, because the described problem doesn't occur if you use E-UAE and WHDLoad together with hardfiles. So, a workaround could be to start E-UAE from a volume smaller than 4 GB (small partition or hardfile).
  • »27.12.08 - 08:54
    dIGIMAN
    It could be a workaround to use a smaller partition
    but a hardfile doest let me run my whdload stuff easy
    anymore.
    I would have to put every little game into a hardfile and could
    not just (nearly) start the games from ambient with a doubleclick.
    Strange that nobody tried to fix this.
    Just saw the source are a bit newer then the latest release but i dont
    think the bug is fixed there
  • »28.12.08 - 19:06
    analogkid
    That's what I had done, i was using a small partition of 2 GB just for E-UAE and WHDLoad-related games. You could also make up a, let's say, 1 gig sized hardfile and mount it as a AmigaDOS-device via diskimage.device. This should also work.
  • »29.12.08 - 08:25
