mkv movie files on morphos
    xyphoid
    Posts: 870 from 2008/7/11
    how do you play mkv files on morphos? I am aware of mkvtoolsnix but I don't know how to get it going. vlc nor mplayer are able to play it though mplayer attempts with lag. this is on efika. Please tell me how to set it up for playing these files. haven't found a gui for mkvtools.
    thanks. :-)
  • »28.12.08 - 17:19
    catohagen
    Posts: 297 from 2003/5/20
    mkv is just another container for video/audio, problem might be your cpu so even if the video you are trying to play was in divx/wmv format it would lag as well on your system, try different options with mplayer, turn on frameskipping.
    try option -vf scale=352:576 for those higher resolution videos.
  • »28.12.08 - 18:05
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Mplayer doesn't just attempt, it plays it. Playback being too slow is just related to efika speed. You seem to expect too much from your efika.
    Paste here what mplayer says about resolution, bitrate and codec (use properties from menu to get it or read shell output, for instance).
    If it's anything above 640x480 resolution or if it uses h264 codec, then an efika just can't play it at full speed.
  • »28.12.08 - 19:00
    xyphoid
    yes, i do most of us newbies are now finding out that you can't expect much from efika! what i said was that i thought the mkv format was a codec that i was missing or something and that mplayer attempted to play it. I came across a format that i was unfamiliar with and did a search on info.
    details:
    resolution = 1280x720
    bitrate a = 640kbps
    v = 0
    codec a = a52
    v = ffh264
    fps = 23.98
    picture- exquisite!
    yep! not playing this file!
  • »28.12.08 - 20:13
  • Fab
    Fab
    Heh, even a pegasos2 G4 can't cope with this. Neither can a mac mini G4 with OSX. A mac mini with MorphOS can, though. :)
  • »28.12.08 - 20:49
