Spreadsheets that actually print.
    matt3
    Posts: 764 from 2004/2/10
    I have tried Turbocalc 3.5, ignition, and star am with no luck printing properly in MOS 2.1.
    Does anyone have any success printing from a spreadsheet?
    Merry Christmas!
    Matt
  • »19.12.08 - 00:04
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 18.04.2011 - 18:57 ]
    Pegasos2 G3, 512 megs RAM
  • »19.12.08 - 01:26
    matt3
    Hi Velcro_SP:
    How good is your experience with Papyrus? Is it worth the money?
    I already own tons in amiga software and would hate to invest in another if it didn't run very well.
    Final writer is a fine word processor, and turbocalc is fine (unless you actually want to print)
    Your comments are greatly appreciated.
    Matt
  • »19.12.08 - 22:43
    Velcro_SP
    [ Edited by Velcro_SP 18.04.2011 - 18:56 ]
  • »20.12.08 - 10:29
    Yvan
    Posts: 79 from 2003/3/28
    I am able to print without problems from Turbocalc 3.5. The output quality is even better when printing from MorphOS than from WinUAE with OS 3.9.
    I use MorphOS 1.4, Peg 1, the printer is an HP 560C, parallel port.
  • »22.12.08 - 12:06
    Schlonz
    Posts: 131 from 2004/4/16
    Hi Matt,
    I cannot recommend Papyrus, it sucks in almost every way since late 2004.
    But I am able to print from TurboCalc 4 and 5. With MOS 2.1 it works like a charm (did not try it with MOS 2.2 yet), and with MOS 1.4 it prints at least in black / white, but only if I use the not-updated Iprefs for MOS 1.
  • »24.12.08 - 20:34
    matt3
    Thank you for the help.
    I was able to make turbocalc 3 print with some playing around with text settings, appears graphics printing doesn't work.
    Do you know what the differences are between turbocalc 3,4 and 5?
    I was curious to see if an upgrade was worth it.
    Merry Christmas,
    Matt
  • »25.12.08 - 05:17
