Copy Softlinks
    dIGIMAN
    Posts: 273 from 2005/11/7
    Hello m8s,
    i am stuck here.
    If i want to copy/clone a partiton to another one, that contains softlinks,
    for eg. the gg:bin/ directory partiton.
    Which is the best to do it?
    A simple copy gghd: gghdnew: doesnt work like expected.
    Thanks for help
    [ Edited by dIGIMAN on 2008/12/15 17:34 ]
  • »15.12.08 - 14:32
  • Targhan
    Posts: 2833 from 2003/2/7
    Try the following:
    copy gghd: gghdnew: clone all
    :idea:Targhan
  • »15.12.08 - 17:02
    dIGIMAN
    Targhan wrote:
    Try the following:
    Thanks for help but somehow this also only creates
    empty directorys where the links should bee.
    To bad there is not Partition Clone Tool.
    Maybe there is no way to copy softlinks?
    This would mean that the GGHD is not replaceable or even backupable :/
  • »16.12.08 - 06:14
    Posts: 3287 from 2003/3/5
    Try using tar
  • »16.12.08 - 07:00
    dIGIMAN
    Good Idea, havent thought about that b4.
    Thanks!
  • »16.12.08 - 10:39
