turboprint correct colors
    amiga4001
    Posts: 450 from 2006/11/16
    I have two printers attached to my peg2.
    One on the parallel port and one on the usb.
    I normally use the parallel one (HP laserjet) for printing as I don't need colorprints that much.
    I wanted to print a picture on the usb printer which is a epson stylus color 880.
    Prints ok but coloring is not ok.
    Tried with pagestream to print a green red and blue circle.
    The green turns out yellow red is ok and blue becomes more pink a like.
    It used to print out ok but is some setting off in my turboprint?
    I played around a bit with settings but not much is changing in printout.
  • »10.12.08 - 19:47
  • Bounty Manager
    insane
    Posts: 68 from 2003/5/20
    I had the same problem with my old Epson SC 600 and with
    my HP ColorLaserJet.
    I replaced the folders mossys:tp\printers and mossys:tp\colors with
    the original 68k version of Turboprint. After that, the colors were OK.
    Turboprint in MorphOS has a lot of bugs...
    Maybe you like to support the "Printing-System" bounty ;-)
    http://bounties.morph.zone/bounties/show/12
  • »11.12.08 - 08:30
