USB with 1.4
    Robert
    Posts: 331 from 2003/5/12
    Hi folks,
    I've been trying to get my digital camera and USB card reader working
    and am getting the message:
    "Couldn't find/load filesystem for usbscsi.device unit 1 as UMSD"
    for both.
    Is there something I have to set up / enable or does it mean my USB
    devices aren't compatible? :-?
    Cheers,
    Robert.
    Robert.
  • »04.09.03 - 20:12
  • HAK
    Posts: 227 from 2003/2/24
    @ Robert,
    Just a guess - as I don't have my cardreader here for checking.
    masstorage.device might be looking for L:fat95 as FAT filesystem here
    (can't remember whether this is the standard setting).
    Is it possible that this one is not installed on your system?
    Bye HAK
  • »04.09.03 - 20:58
    Robert
    @HAK:
    That sounds promising. If so, how do I install it?
    Thanks again,
    Robert.
    Robert.
  • »05.09.03 - 08:29
    Spidey
    Posts: 568 from 2003/2/24
    Hi Robert,
    For starters you can download the Fat95-package from aminet here and install it on your system.
    Good luck,
    Spidey
  • »05.09.03 - 08:48
    Robert
    Hi Spidey,
    I downloaded Fat95. where do I copy it to?
    The installer doesn't seem to work (I have installer working for
    everything else) and the read me says something about editing the
    installer to make sure it meets my needs!?!?!?!?
    Cheers again,
    Robert.
    PS. Still love your avatar. :-)
    Robert.
  • »05.09.03 - 15:55
    Miky060
    Posts: 694 from 2003/2/24
    You only need to copy fat95/l/fat95 in your L: Is in this drawer that AmigaOS/MOS stores file systems and handlers.  :-)
    P.S. Let us know if your Camera will work with MOS. I'm courious to know even because I have one and I have never tryed. I'm courious also because I am been never lucky with my devices and MorphOS: I have an USB cam and it's not recognized by Poseidon, I have a Logitech USB mouse and is not recognize by Poseidon (or more precise it's recognized but it doesn't work..), I have a joypad that doesn't work with MOS, maybe becuase it has too many buttons for it and at the end I have a Canon i550 printer for wich there is no driver in Mos. =)
    ..let's don't talk about the TV card that is parked in one of my PCI slot, a Plextor 40x CD-Rom SCSI parked in a 5.25 bay and about my 'famous' Radeon 8500 that has still no 3D (as all Radeons..) and most of all that it's the ONLY one GFX board model supported by MOS that has still no overlay support!! I'm a really lucky guy chooseing boards and peripherals!! :D :D :D
  • »05.09.03 - 16:30
    Robert
    @Miky060:
    Thank you - it works now.
    Yes, my camera can download pix to Morphos now - woohoo!
    Cheers,
    Robert.
    Robert.
  • »06.09.03 - 15:26
    DedyAmigo
    Posts: 41 from 2003/7/19
    Hi Spidey,
    can You help me with my digicam CANON PowerShot A40? I think that USB version for this cam
    no support masstorage, and I don`t know what
    I can do in this case. Sory for my english,
    and much thanks for your answer.
    DedyAmigo
    Dedy
    http://amigo.bodli.net
    Powerbook G4/1.67GHz, MOS 3.17 reg
    Asus Zenbook UX32VD, Xubuntu 20.04
  • »06.10.03 - 18:00
    Jupp3
    Posts: 1193 from 2003/2/24
    can You help me with my digicam CANON PowerShot A40? I think that USB version for this cam no support masstorage, and I don`t know what I can do in this case.
    If it has separate memory card (as most digicams do) you could use separate memory card reader, but beware, not every reader is compatible with Poseidon...
    Your camera MIGHT be using propietary format for storing pictures (most don't), if it does, you're in trouble...
  • »07.10.03 - 13:22
    DedyAmigo
    Thanks, I am afraid of it
    Dedy
  • »07.10.03 - 18:04
    Posts: 35 from 2003/9/27
    http://www.powershot.com/powershot2/a40-30/specs.html
    File Format Design rule for Camera File system (DCF*1), EXIF v.2.2 compatible
    Don't know much about filesystems (if its proprietary)
  • »07.10.03 - 18:56
