Posts: 348 from 2004/8/31
General information: GPL license put the build tools chain into the system.
So, you don't have to release sources of tools used to make the code and to built it...
... or Windows is totally open
Now about the "builtability" of sources: GPL doesn't force also that the build chain works perfectly, you have just to provide the same "sources" that permit to obtain the binary provided. As the make-mos.py scripts is really easy to read and to convert to a Makefile, and as Makefile.old files are provided also in the sources archives, any "good" coder is able to produce the binary in more or less 10 minutes.
@tokai: Your logic should enforce to provide system SDK in the sources archive and so on.. and you know it's not the case.
So I think that your post is useless, false. And you are really too lazy
Anyway, thus how know what's dot, should know what to do with... others ones SHOULD use google.
Final words: I've provided this, as it, without think to support it later. For thus that doesn't know yet, I'm too busy on some important and needed projects, like the Firewire stack.
[ Edited by Yomgui on 2008/12/5 10:09 ]
And now... next project!
