TwinVnc + Germankeymap = no PipeCharacter
    judas
    Posts: 175 from 2005/1/14
    I like TwinVnc a lot.
    Most of the time, I contact a system running tightvnc on Linux.
    Unfortunately I cannot enter the "|" character with tightvnc.. all I get is a flash on the MorphOS-Side.
    Pipe is very essential to me, so I'm very interessted to get this working ...
    Any hint, what to try ?
  • »29.11.08 - 14:48
    weiseb
    Posts: 215 from 2003/3/29
    in kde console i have to use
    shift alt instead of alt gr
    (but in xterm alt gr works)
  • »29.11.08 - 19:36
    judas
    Very strange .. but with your hint, I found a solution:
    In Vnc I must use left Alt and shift to get the "|".
    With right Alt-gr and shift I get nothing but red blinking windows on MorphOS.
    ( If this keyboard is directly connected to a linux machine, I must use Alt-gr to get the "|".)
    Thanks a lot.
    [ Edited by judas on 2008/12/2 22:47 ]
  • »02.12.08 - 19:47
