opening url from yam in sputnik
    amiga4001
    Posts: 454 from 2006/11/16
    Using mos2.1 with yam here and using sputnik as main browser nowadays.
    But somehow I can't seem to get yam to open sputnik with the doubleclicked url in yam.
    Yam opens sputnik but with nor url even clicking again doesn't work.
    I also tried setting openurl to ibrowse but same story.
    I did upgrade openurl to later version maybe this conflicts with version included with mos2.1?
    Believe I removed all off the openurl install from the 2.1 install...
    Still configuring seems to work in the menu as setting it to Ibrowse opens ibrowse etc..
  • »02.12.08 - 19:00
    Posts: 1095 from 2004/9/23
    I had the simular problem once. Maybe its related.
    Check the configuration section "script" "double click on URL" and make sure its empty.
    Geit
  • »02.12.08 - 19:31
