Creating VideoCD compliant MPGs using FFMpeg or Mencoder?
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hi.
    I want to convert movies from different formats into VCD-compliant MPGs using either FFMpeg or Mencoder, in order to pass them to VCDGear and create VideoCD disks that will play on a home DVD player.
    No matter what arguments i use, the converted movies always have some A/V sync problems etc.
    Could anyone who has done this successfully paste the exact command-line that he is using? Thank you.
    [ Edited by AmigaMancer on 2008/11/17 18:22 ]
    Amiga 1200 user.
  • »17.11.08 - 16:19
    Wishmaster
    Posts: 342 from 2003/6/29
    http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-mpeg.html
    Pegasos PPC
  • »20.11.08 - 01:03
    AmigaMancer
    @Wishmaster
    I believe that i have tried every suggested argument in the manual of Mencoder, but i still couldn't make it to output a 100% proper VCD MPG stream. Anyway, i got some nice tips from A.org and i will apply them to see if they will resolve the problems i encountered. Thanks.
    [ Edited by AmigaMancer on 2008/11/20 18:38 ]
    Amiga 1200 user.
  • »20.11.08 - 16:23
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    ffmpeg add parameter -bf 1 and -f vcd, create in vcdimager.
    _
  • »21.11.08 - 17:44
