MorphOS 2.x error
    Posts: 236 from 2003/7/28
    After doing a clean install to MorphOS 2.0 and then 2.1 I get the following error message:
    Error - click here
    Does anyone know how to make this error "go away". It doesn't appear to affect anything...but every time I reboot it comes back.
    Thanks.
    PS - I have a Pegasos II G4.
    [ Edited by HammerD on 2008/11/19 17:39 ]
  • »19.11.08 - 20:38
    Tcheko
    Posts: 540 from 2003/2/25
    Hi HammerD,
    By default, all network interfaces are up. I guess you have only one interface on you pegII used.
    Two solutions :
    - plug the unsused ether somewhere or
    - edit the interfaces file (IIRC) in env:sys/network and comment the unused interface.
    Czk.
  • »19.11.08 - 23:09
