Overscan
    CountRaven
    Posts: 566 from 2007/12/10
    Hey just wanted to ask if there is a tool similar to OverScan -found on AmigaOS 3.9-, located in MorphOS.
    Need to move the margins of my screen just a click to the right. Had managed to create a smooth resolution -1024*768 in 85Hz- ussing my Radeon and I just want to have this fixed. In Linux there is also a way to center the screen via software, can I do the same in MorphOS 2.1? Thanx.
    ps. If I have posted it to the wrong place, mods please move it, thanks.
    ps1. Hey I also wanted to ask how can I actibate the 3D Layer on MorphOS boot. Thanx.
  • »31.10.08 - 01:54
    MarK
    Posts: 641 from 2004/1/25
    well, this ofcourse works in the monitor settings, you can set offsets... but else, use monitor to move the screen over the crt...
    bye, MarK.
  • »31.10.08 - 04:51
    CountRaven
    Thanks man, I know that I always can move the margins from the monitor panel but I just want to know if there is a software tool via MorphOS to do it. On the "Monitors" setting tool from the "System" menu I was unable to find such a tool, the same goes and for the "Screens" selection. Any ideas?
  • »31.10.08 - 11:49
    CountRaven
    Ok, found it. Thanks :))))
  • »01.11.08 - 13:43
    xyphoid
    Posts: 870 from 2008/7/11
    --dont know if you mean this but
    esc boot boot.img 3d
  • »01.11.08 - 19:31
    Phantom
    Posts: 381 from 2004/9/7
    Type this on the firmware.
    Boot boot.img 3D RD
    * RD stands for RamDebug
  • »04.11.08 - 16:32
