Ambient usage - features
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Of course i mean amigados.
    About openurl, it would be surprising it wouldn't work, but if it really doesn't, just use the full path... :)
  • »27.10.08 - 16:49
    March
    Posts: 91 from 2003/7/30
    The openurl command is not a part of MorphOS 2.x iso. Please download it from Aminet: http://aminet.net/comm/www/OpenURLMOS.lha
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »28.10.08 - 09:23
    Posts: 423 from 2005/4/9
    thx!
    it works - kinda. openurl launch the browser, but now ibrowse complains that "this protocol is not supported" (localhost:// is missing). i will use the full path i guess:)
    zx.spectrum@3.5
  • »28.10.08 - 10:15
  • rms
    rms
    Posts: 604 from 2004/11/27
    Hi all,
    I installed it the following way:
    (amigados) openurl %sp
    this works for liks on the internet but now I have the problem when I double click on a locale file it wont open because there is "http://" in front of the path.
    Can anyone help.
  • »29.10.08 - 04:31
  • Fab
    Fab
    I didn't write "openurl %sp" but "openurl %sp FILE", which makes the difference. :)
  • »29.10.08 - 11:35
  • rms
    rms
    @ Fab
    I am SORRY but I didn't understand what you had ment :-(
    I made the change and it works fine now! Tnaks very much for your help.
    Regards
    Christoph
  • »29.10.08 - 14:07
