MorphOS 2 skins
    serge
    Posts: 725 from 2003/2/20
    Is there somewhere a new skin using MorphOS 2 improvements?
    I would like to saw it to learn how to create new skins with transparency.
    Maybe it exists a tuto?
    Maybe someone can tell us how to do.
    Thx.
    Serge
  • »12.10.08 - 19:02
    tokai
    Posts: 1289 from 2003/2/25
    I fixed your topic. Please avoid 'MOS'. Thanks.
    About your problem... have a look how the other skins provided with the OS doing it and learn what is possible. Try some PNGs with Alpha channel maybe. ;-)
  • »12.10.08 - 20:44
    serge
    Ok, thank you tokai.
    About skins provided with Morphos, I dont saw transparency :-( Should you give me a skin name using it please?
    bout PNGs with Alpha, I tryed it without succes :-( Instead of transparency I have black.
    Can I use alpha on all GFX? borders, gadgets title barre?
    thx
    So, so so. Il will search more by myself.  :-)
    I started my brain this morning and some ideas came on it ;-). For black instead of transparency, maybe I need to invert alpha, and for new skins using transparency, maybe this nice effect was used with elegance and it dont hurt my eyes ;-)
    I will search more and come back her to tell what I found.
    [ Edited by serge on 2008/10/13 8:29 ]
    [ Edited by serge on 2008/10/13 8:32 ]
  • »13.10.08 - 05:00
    Posts: 3266 from 2003/3/5
    MorphOS 2.0 comes with skin enchancements for the titlebar. Sadly our gfx artist didn't have enough time to make such skin yet. I'll see if I can make some reference skin for the SDK.
  • »13.10.08 - 05:29
    serge
    @tokai: I dont found any skin using transparency on MorphOS 2 :-(
    unfortunatly PNGs with alpha dont make transparency, but alpha is displayed black.
    @Hi jacadcaps:
    thank you very much.
  • »13.10.08 - 15:22
  • ASiegel
    Posts: 1396 from 2003/2/15
    @serge
    You need to boot MorphOS with enabled 3D layers in order to build or use skins that feature 8BIT alpha masks.
  • »13.10.08 - 17:23
    serge
    JoBBo wrote:
    @serge
    It's the case. I'm using 3D layers, but Alpha doesn't work.
    Do you have a skin example please?
    [ Edited by serge on 2008/10/14 6:18 ]
  • »13.10.08 - 18:16
