3rd party sbar plugin
    Tcheko
    Posts: 544 from 2003/2/25
    Yay,
    Any sbar plugin out apart delivered one with 2.1 update?
    Czk.
  • »06.09.08 - 20:22
  • rms
    rms
    Posts: 606 from 2004/11/27
    is under MorphOS2.1 a possibility to have the amount of used and available RAM shown e.g. in the s.bar? Like it was possible with statline?
    Or do I have to reinstall statline?
    Regards
    Christoph
  • »06.10.08 - 20:09
    Posts: 1087 from 2003/3/24
    If you wan't more try this link: http://ultragelb.com/beta/
  • »07.10.08 - 05:19
    Gelb
    Posts: 148 from 2003/3/4
    And who told you to make this link public? Besides, why do you have that link at all?
  • »07.10.08 - 10:36
    No one told me to make it public, i thought it is public, cos in this thread it was posted by Leif: https://morph.zone/modules/xoopspoll/pollresults.php?poll_id=90
    But something else how can i report bugs? I have tried by email but i can't find your adress and on the AmigaZeux Page it's no longer possible to register to post bugs on the Bugtracker.
    Oh and one more thing i realy appreciate your work.
    Will you ever update WetterNG and MEM to work with MorphOS 2.x and 3dlayers eneabled?
  • »07.10.08 - 10:43
  • rms
    rms
    @ ThePlayer
    thanks for the link but it seems not to work :-(
    Well I was just aking if there will be a plugin which shows RAM, it would be handy for me...
    Regards
    Christoph
  • »08.10.08 - 12:36
    Posts: 12572 from 2003/5/22
    Read Gelb's reply to know why it doesn't work anymore.
    > shows RAM
    There was one at the linked webpage. Although it's not there anymore I'd say yes, there will be such plugin as soon as Gelb decides to release it :-)
  • »08.10.08 - 15:58
  • rms
    rms
    @ all
    thanks for all your feed-back. So I (we) have to wait then. I'm looking forward to it.
    Regards
    Christoph
  • »09.10.08 - 10:28
