strange prob with aminetradio on MorphOS2.1
    judas
    Posts: 175 from 2005/1/14
    One of my Pegs is a plain new installed 2.0-2.1 system.
    Now I tried to get my Apps from 1.45 copied, but ANR gives me some headaches:
    The window-section below the title bar doesn't show any animations any more.
    It's just a green rectangle.
    Shoutcastsearch doesn't find any channels, but playing my bookmarks works well.
    (Network is working well with browsers..)
    I allready did some experiments with copying mui-classes, but didn't succeed.
    Any hint, what could be wrong ?
  • »03.10.08 - 08:15
    AyoS
    Posts: 410 from 2003/8/13
    1. I found the same thing... but once I changed
    Skins it worked. Right now I use another skin
    So I don't know what the problem is.
    2. There is a new Shoutcast Ip address. I use http://classic.shoutcast.com
    there was an earlier thread that i got my info from.
    3. It is possible that it is a mui.class issue, but I doubt
    when other skins work?
  • »03.10.08 - 08:59
    Posts: 1087 from 2003/3/24
    Afaik you have to change the GUI or to boot without 3dlayers.
    Shoutsearch need's a new Server the old one isn't working anymore.
    Click "Hot & New" button on MZ.org there you will find a thread about ANR and Shoutsearch.
  • »03.10.08 - 09:01
    judas
    ThanX a lot !
    With the new server, search works now.
    I switched the gui to winamp, which works for me, although I'd better like the classic gui, because it's the coolest of all skins for me..
  • »03.10.08 - 09:29
    kriz
    Posts: 314 from 2005/10/18
    Yeah, I also like most the old gui... But for me it doesnt show animation either, only white yesterday when i checked...:(
    Also when searching in Shoutcast :
    It shows the wrong field in quality and listeners.. So I cant check the quality of the stream.... Anyone else seen this ?
  • »03.10.08 - 10:25
    Posts: 12572 from 2003/5/22
    Yes. It has been this way for at least a year now.
  • »03.10.08 - 10:51
    tokai
    Posts: 1289 from 2003/2/25
    This is a long standing issue. I call it the 'pink bug', because here it makes my ANR GUI pink. Sadly we didn't could locate the source of the problem yet.
    My guess is still that it's an ANR bug (it was triggered by changes in the OS though), even if UltraGelb says it isn't (previously it was worst as the whole GUI and not only the blurry part of the scroller was wrongly coloured. With changes in ANR that was fixed though.). ;-)
    regards,
    tokai
  • »03.10.08 - 12:15
    SoundSquare
    Posts: 1214 from 2004/12/1
    yup same here
  • »03.10.08 - 14:28
