Posts: 870 from 2008/7/11
TheMagicM wrote:
btw, how do you like your new, functioning 2.1 setup?
haaa, good! only minor issues with the logitech mouse/keyboard combo dropping one or the other, usually under a load ctorrent or sputnick,(how do you clear the ram for it anyway)
Secondly before mentioned hang with blank cd's on the hp630edvdrw. hoping the new lite-on i ordered works so i can burn cd's.
in all honesty i need to do word processing, surfing and burning to be really pleased.
What are you doing with blender?
