Mounting network disc, how to?
    XzIt
    Posts: 250 from 2005/1/19
    Got this nice network drive at home using to share stuff on the local network.
    But how do i mount this in MorphOS, is there any program i need etc?
    plz let me know if your using a network drive and have it working with MorphOS.
    X  8-)
  • »17.09.08 - 11:12
    Tcheko
    Posts: 544 from 2003/2/25
    Yay,
    You can give a try with SMBFS 1.66 available on aminet.
    To mount a smb guest share (no password) :
    run >nil: smbfs workgroup=nameoftheworkgroup service=//nameoftheserver/nameoftheshare
    This shall work straight away.
    If you want to see the share on the ambient desktop, add volume option with the desired name. Don't forget to add a disk.info on the share.
    smbfs can be launched from wbstartup drawer. Add an icon, set some tooltypes (workgroup, service, etc...) and tada.
    Czk.
  • »17.09.08 - 11:16
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Disk.info is not needed.
    And if you want some specific icon, you can also just have a def_smbfs0disk.info in your deficon path (sys:prefs/presets/deficons/ by default). Its representation mode & icon/window position will be saved too.
  • »17.09.08 - 11:52
    Posts: 2217 from 2003/2/24
    And remember to add stack for smbfs before launching it. 32768 for example.
  • »17.09.08 - 13:07
    XzIt
    thx! helped a lot...
    X
  • »18.09.08 - 20:30
