x11 and texmacs
    methodwares
    Posts: 4 from 2003/10/2
    I am seriously considering getting a peg as I use to be an amiga owner (the old 3k got sold as I moved from the uk to england and well didn't know if i could get stuff to convert the power). The only thing I really would like is an X11 server, I know there was one for the amiga, as I use texmacs alot which depends heavily on X. Anyone know if there is one for Morph.
    And yes I know linux works on the peg, but I have a linux box at home and doubt I would want to run it on the peg as, well, that is what morph is for
    thanks
  • »02.10.03 - 13:38
    td741
    Posts: 224 from 2003/4/2
    AFAIK there isn't one that's Morph native. Which one are you using? Is there a demo version on Aminet? I can test it out for you.
    Steph
  • »02.10.03 - 14:13
    methodwares
    I looked on aminet and there are a couple of them... can't remember which one I used... 'twas many moons ago
    thanks
  • »02.10.03 - 15:18
    td741
    Hmm... I guess I'll give it a shot then.
    I found this: http://dspach.free.fr/amiga/xami/ . I'll see if I can get it up and running.
    Okay, found also AmiWin and GfxBase demo versions, but umm... Not sure if there is a way to buy these anymore.
    Steph
  • »02.10.03 - 15:30
    td741
    Test results:
    - tested on my small lan, using the Sun box and my Pegasos w/MOS14. Essentially I exported the sun's display to my pegasos. :P
    XAmi402: freeware, umm, started up fine, but crashed after 2 seconds... and I mean crash and burn (system locked up tight.)
    AmiWin222: Shareware (demo). Seemed to work fine, it was limited to 8bit screens, and I couldn't select anything over 800x600 for some reason. However, it worked. I believe the demo is timed to 30 minutes or something and I don't think you can register it anymore. :(
    GFXBase-X11: umm... couldn't get it run. Says it's obsolete. There's a date check, I put the clock back temporarily but it didn't work.
    Steph
  • »03.10.03 - 04:07
    methodwares
    hmm, thanks for trying, still want a peg though
  • »03.10.03 - 09:35
    tokai
    Posts: 1289 from 2003/2/25
    AFAIK there's also a X11-Server (+ a lot X11 programs ports) in the GeeksGadget system.
    http://www.ninemoons.com/
    After you have installed the MOS SDK (which comes with a basic MOS native geeksgadget environment) you could try to install the x11 packages. It will be awkward, but could run! Maybe someone has the time to test this out. :-)
  • »03.10.03 - 10:55
