Posts: 444 from 2006/11/16
Ok not morphos related but still.
I got this livecd off puppylinux which i use too boot an old laptop.
This one is only 256MB and 700MHz Athlon or something so I thought nice os for this machine.
I booted the cd and installed the os onto the harddisk.
Booted up but now freezes at GRUB command.
Only way too boot it up now is with the livecd and this command ..puppylinux pfix=ram
Before this it booted up one time ok but after setting the IP stuff for internet which worked ok it freezed at the init off the network(or pcmcia card?).
After that the grub freeze..
Help it seemed a very nice os low spec and I was just aboit too like linux and maybe try a install onto my peg2.
