DRAGON come back PLEASE !!!
    serge
    Posts: 725 from 2003/2/20
    Hi guys,
    I'm very sade to be obliged to leave DRAGON since MOS 2 was installed on my PEG.
    The Cube added to MOS a nice way to switch screens, but about me, this last one dont replace all the work done by Dragon.
    About me, the Cube and Dragon are complementary.
    What do you think about the lost of Dragon and whould you like to have a new Dragon using 3D layers?
    May be his author is working on it at this time or maybe he is needing to be supported to do it  :-)
  • »22.08.08 - 14:36
    Posts: 918 from 2004/1/24
    Funky as Dragon is, you actually made practical use of it?
  • »22.08.08 - 15:21
    Get27
    Posts: 90 from 2004/8/23
    +1 Serge
    or maybe the author have not bought MOS2 :-)
    [ Edited by Get27 on 2008/8/22 18:49 ]
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »22.08.08 - 15:26
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Just tested and Dragon still works here.
  • »22.08.08 - 16:32
    serge
    It's incredible !
    It's working this evening !!!
    I dont understand what hapends the first times when I tryed it without succes.
    It's working just fine.
    It's realy funny and I'm happy  :-)
    Edit:
    OK, I remembre something changed since my first try.
    I had a Radeon 7000 64 mo and now I have a radeon 8500 128  :-)
    The amount of memory should be the reason.
    [ Edited by serge on 2008/8/22 21:35 ]
  • »22.08.08 - 16:52
    motorollin
    Posts: 74 from 2006/8/30
    What's Dragon?
  • »23.08.08 - 08:05
    stephen_robinson
    Posts: 746 from 2007/4/22
    Screen dragging utility, I found it useful, but i couldn't get it to work on MOS2.0, hmm, maybe I should try again...
  • »23.08.08 - 08:20
    motorollin
    Oh right, "drag on" ;-) I was wondering if there was a way to drag screens in MOS. Might give this a try! Where can I get it? Can't find it on Aminet or in the download section here.
  • »23.08.08 - 08:29
    kriz
    Posts: 314 from 2005/10/18
    http://amigazeux.net/dragon/ - Check also the other stuff from them, lots of cool stuff..
  • »23.08.08 - 09:14
    serge
    Do you use Lucy?
    Lucy created a little trouble on me cause she uses the leftsiht key as qualifier.
    Dragon uses to leftshit as qualifier, so when you press leftshit + mouse click, there's only 1 commodity responding to it.
    We must change the qualifier key for one of the commodities.
    Now all is fine.
    I think I had some troubles with my old radeon 7000.
    Now I get a radeon 8500 128mo and all is ok.
    [ Edited by serge on 2008/8/23 12:38 ]
  • »23.08.08 - 09:36
    stephen_robinson
    Hmm, I can get the Drag anywhere to work, but I don't want to use the keyboard, I just want to grab the title bar, hold down the left mouse button and go, can't seem to get it to work, even with Lucy disabled...
  • »23.08.08 - 13:23
