EFIKA sound support (when?)
    TheMagicM
    Posts: 1220 from 2003/6/17
    when are you guys planning on getting that portion implemented?
  • »27.07.08 - 04:28
    TheMagicM
  • »02.08.08 - 18:55
    Posts: 1087 from 2003/3/24
    When it's done ;)
  • »02.08.08 - 20:44
    Posts: 608 from 2003/4/11
    In fact it IS already implemented and will be included in the next update. Don't ask for a release date of this one, though .... It will definitely not be far away and addresses many of the issues which users discovered with 2.0.
  • »02.08.08 - 21:03
    TheMagicM
    pega-1: ok thanks. btw, is an update for *registered* users or for all users?
  • »03.08.08 - 03:22
    pkillo
    Posts: 11 from 2008/7/11
    how will the update be distributed? is it an automatic process or will we have to dl and install it?
  • »03.08.08 - 05:13
    I think it will be the later, DL and install.
  • »03.08.08 - 05:22
    This update will be available for all users, unregistered users may evaluate the updated version as usual.
  • »03.08.08 - 14:15
    Tronman
    Posts: 209 from 2003/3/3
    Radical! I like that it will be available for all to use. I'm afraid I haven't been able to cough up the USD$$ for MOS 2 as yet. When I finish getting out of subprime mortgage hell, then I can :-(
  • »04.08.08 - 05:38
  • Targhan
    Posts: 2833 from 2003/2/7
    I suspect that there will be several ways to distribute the OS. However, keep in mind that it will have to be registered.
    :idea:Targhan
  • »04.08.08 - 17:39
    TheMagicM
    Targhan: pega-1 said its for registered and non-registered users alike. Are you referring to the sound patch? or something else?
  • »05.08.08 - 00:07
    xyphoid
    Posts: 870 from 2008/7/11
    is the reg tool still the only way to register? i'm not connected through highspeed, haven't got a wireless opt yet, dont think there is a dialup opt. on efika.
  • »05.08.08 - 00:32
    Neko
    Posts: 301 from 2003/2/24
    Of course you could run the updates and sound on an unregistered MorphOS, but with a 30-minute time limit you had better have some very short albums to listen to :)
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »06.08.08 - 09:50
    TheMagicM
    I'm not going to be unregistered for long :) just got back from Cancun..so I need to get back into the swing of things, then I'll register :)
  • »10.08.08 - 00:58
