SoundBlasterLive problems..
    Jambalah
    Posts: 820 from 2008/3/30
    Ok.. Today I found a SBLive at lower cost and I bought it. Installed it, tried live Mixer and it found the card.
    I have a normal 2.1 speakers system (a sub and two satellites) and I tried to connect to the card.
    I opened configuration window and selected emu10k mode (16 bit stereo ++) and saved. Tried some music (cd player, ANR, AmigaAMP)
    but I heard no sound at all. Well I thought I connected speakers in a wrong way so I changed connector position on the fly freezing system.
    I booted again and... surprise! Opening config window and selecting AHI the emu10k modes are missing! Disappeared!!! Trying to start LiveMixer again
    "unable to open DEVS:AHI/emu10kx.audio".. I checked: it is there!
    What the f:xxx: is happened?!? :-?
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »18.07.08 - 23:41
    diezi7
    Posts: 167 from 2005/7/26
    Hi Jamabalh
    this same thing happened to me. I think my card died, so I replaced SBLive with a new one. Does it appear with PCIInfo? Mine didn't cause it was dead
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »19.07.08 - 14:05
    Jambalah
    @ diezi7
    Thanks for the info. I will try when I could...... My Peggy seems died.... :cry:
    Pegasos II 1 ghz
  • »19.07.08 - 14:50
    Phantom
    Posts: 381 from 2004/9/7
    When I installed my Soundblaster on MorphOS 2.0 everything was done automatically!
  • »19.07.08 - 15:28
    magnetic
    Posts: 2129 from 2003/3/1
    yes Soundblaster live WITH EMU 10k CHIP ONLY (a lot of sb lives DO NOT have this chip its another check your board ) if it does it works OOTB on M2 and pegasos2. Mine did, however I do have an issue with low volume that mos team are aware of and will be fixed in the next release afaik.
  • »20.07.08 - 04:19
    Jambalah
    Chip marked with "Creative EMU10K1-SEF". MOS recognised it and showed some EMU10K modes in AHI config. But I didn't hear any sound at all.. Then after a pair of freezes emu10k audiomodes disappeared and livemixer didn't find the board anymore. I couldn't check with PCIInfo, as suggested by diezi7, because of general fault of Peg... :cry:
    Well... C'mon... I will solve it!
    Pegasos II 1 ghz
  • »20.07.08 - 09:11
    diezi7
    Maybe you could get to OF and watch if it's listed as PCI Device.
    I hope you can restore your Peg, good luck !
  • »20.07.08 - 15:41
    Jambalah
    @ diezi7:
    thanks man! I checked PCI in firmware: no soundcard detected.
    SBLive is dead, I presume.. :-/
    This is really a good week, nothing to say...
    :lol: laugh, never cry!
    Pegasos II 1 ghz
  • »20.07.08 - 21:10
    diezi7
    Maybe your SBLive died if it wasn't correctly inserted
    onto de PCI slot. It's easy, you can replace it with
    another one ;-DD They are quite cheap and easy
    to find
  • »21.07.08 - 23:37
