Current status of UAE
    dholm
    Posts: 296 from 2003/9/1
    I noticed that the latest UAE (0.8.22) was released quite some time ago and that the latest WinUAE (0.8.22 R9) seems to have many more features (at least if you check the changelog).
    Is the original UAE dead? Should we start a project to backport WinUAE to libSDL or are UAE releases just far apart?
    Has someone tried forking UAE before?
  • »27.09.03 - 11:16
    Coder
    Posts: 296 from 2003/3/5
    Hi dholm,
    At the moment no one is working on UAE for MorphOS. So it's at a dead end. Really bad if you ask me. Just like you I like to see a regular updated version of UAE for MorphOS. But that project idea of yours sounds good. Maybe that is the way to go. Anyway on www.flyingpaper.com I got a forum for UAE for MOS. From tomorrow on I will be active again on that.
    Coder
  • »28.09.03 - 17:14
    DJBase
    Posts: 745 from 2003/4/6
    The latest version I have is 0.8.22 with fixed AGA done some days ago. You can find it on www.pegasosforum.de or www.djbase.de
  • »28.09.03 - 18:12
    dholm
    Thanks, 0.8.8d didn't work for me at all.
    I was inquiring towards general UAE though, not the MorphOS version.
    Are there any cross-gui libs that work on MorphOS as well as Linux and MacOS yet? If someone is to port winuae they need a good gui implementation =).
    Oh, and is it possible to run UAE on Linux in fullscreen? I thought I'd make my powerbook into a portable Amiga instead ;)
  • »28.09.03 - 19:15
    warface
    Posts: 653 from 2003/2/24
    Wow, now that is way ahead of the one I had before, thanks!
  • »29.09.03 - 09:40
    td741
    Posts: 224 from 2003/4/2
    Woohooo... Joypad support! :-D
    Steph
  • »29.09.03 - 15:04
    Doraemon
    Posts: 137 from 2003/7/1
    I want to use the luise hard disk file with these nice gui.
    http://louise.amiga.hu/
    Anyone can sayme the correct way?
  • »29.09.03 - 22:06
