MorphOS Developer
Posts: 1090 from 2004/9/23
Yes I know it works, I have it. I'm not sure if i have the latest version,
I guess you have
but do you have to select each channel and tune it by hand? Its the only way I have it working so far and will take a long time to make over 100 channels!
Where the hell you're living? Even here there are only 33 programs in analog cable and the number goes down and down to make space for DVB-C channels.
Via antenna here is only one program left.
But to return to your question: No, there is no way of performing an autoscan. It was planned to be build in, but since I dropped the project for the successor, I never did.
Geit
[ Edited by geit on 2006/8/1 19:47 ]
[ Edited by geit on 2006/8/1 19:48 ]
