Where can I find Virtual Grandprix 2??
    Zetec-s
    Posts: 198 from 2008/7/10
    Right, just got my Efika up and running and now I'm looking for Virtual Grandprix 2 to run on it. Only problem is I can't find anywhere to download it from. As far as I understand it was a free download?
    Anybody able to help?
    Thanks
  • »17.07.08 - 11:14
    Posts: 2217 from 2003/2/24
    If Efika's mem is enough then....
  • »17.07.08 - 11:56
    Zetec-s
    Well I tried running it, and can't get it to boot on my Efika, so think memory might be a problem. Then again completely new to Morphos so it might be me  :-?
  • »17.07.08 - 20:35
    guruman
    Posts: 462 from 2003/7/21
    Memory is definitely not a problem on Efika if you stick to the standard res textures, I tried it myself and still had a good quantity of free mem while running the game.
    The fact that zip for MorphOS doesn't preserve the protection bits might be the problem, instead.
    So, open a shell, cd to the VGP2 dir and type
    protect #? +rwed all
    ( #? is the MorphOS DOS equivalent of * in linux, +rwed means that a file is set to be readable, writable, executable and deletable, all means that the operation is repeated recursively into subirs as well)
    Hope this helps.
    Kind regards,
    Andrea
  • »17.07.08 - 21:39
