Software must have
    Posts: 278 from 2003/3/4
    I am back after a few years without hobby life.
    What are the applications must have ?
    So far I have installed:
    AmiNetRadio
    AmIRC
    Tubexx
    Mplayer
    Snoopium
    What else ?
  • »08.07.08 - 18:54
    magnetic
    Posts: 2129 from 2003/3/1
    Christophe!
    Welcome back! :bloons:
    Hey how'd you install ANR? With latest version I get the errror "no bullet soemthing version 0" I Have this libraary installed bullet.library or something..?
  • »08.07.08 - 19:32
    Daff
    Posts: 247 from 2003/4/5
    MorphOS 2.0 (there is Snoppium and Sputnik inclued)
    Blender
    Warzone 2100
    Frying Pan
    http://obligement.free.fr
  • »08.07.08 - 19:37
    SixK
    Posts: 72 from 2004/11/16
    Only "Must have" tool is iKill !!!
    I wonder how I could live without it before !?? :)
    SixK
  • »08.07.08 - 19:48
    Cego
    Posts: 738 from 2006/5/27
    HD Rec
    Amigift
    PolyOrga
    fxpaint
    ftpd
    SimpleMail
    Jabberwocky
    Flash Player
    amifish
    mmkeyboard
    Elastic Dreams/Fantastic Dreams
    MAME :D
    a lot of stuff is already included in morphos2.0, so it depends on what MorphOS Version you use.
    best regards cego
  • »08.07.08 - 20:48
    XzIt
    Posts: 250 from 2005/1/19
    I can't get Elastic/Fantastic dreams to work properly.
    open's a black screen, nothing on the screen at all.
    Some troubles with HD Rec as it crashes randomly, could be Soundblaster Live maybe?
    Anyone got same problem?
    X
  • »09.07.08 - 09:52
    Tcheko
    Posts: 540 from 2003/2/25
    What else ?
    A nespresso ? :)
  • »09.07.08 - 10:15
    diezi7
    Posts: 167 from 2005/7/25
    BTW: Anyone has tried SabreMSN?
    Does it work fine? Screenshots showed are cool ;-D
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »09.07.08 - 13:50
    Posts: 1084 from 2003/3/24
    Yep Sabre works here without Problems.
  • »09.07.08 - 17:00
