sending directory through email
    amiga4001
    Posts: 454 from 2006/11/16
    Is it not possible to send a directory including it's contents through email?
    When I use YAM and I drop a dir into the attachementwindow it only show it's contents.
    Simplemail seems to do the same thing.
  • »07.07.08 - 19:32
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    Compress the directory and its contents in an archive, with lha for instance. Then attach the archive to your email message.
    This is the main reason why archiving tools exist (the other reason is data compression).
    [ Edited by DoctorMorbius_FP on 2008/7/7 23:17 ]
  • »07.07.08 - 20:13
    Jambalah
    Posts: 820 from 2008/3/30
    I tried compressing the whole directory and SimpleMAil sent it. When it will arrive to destination you'd only un-lha.
    Pay attention to big directories: I tried with a 9.8 meg of dir and SimpleMail didn't send it.
    Maybe I exceeded with lenght of file limit.
    Bye
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »07.07.08 - 20:19
    Jambalah
    Woops, sorry Doc...! I was writing while you were posting... :-)
    Pegasos II 1 ghz
  • »07.07.08 - 20:21
    DoctorMorbius_FP
    Note that lha is aware of Amiga attributes (filenotes and the hspa bits besides the usual rwed bits), so the receiver of your archive will be able to retrieve this information.
    Other tools ported from the Linux world simply ignore those data.
  • »07.07.08 - 20:34
    Posts: 12572 from 2003/5/22
    > ignore those data.
    Zip from Info-ZIP is able to store filenotes with '-N' option.
  • »07.07.08 - 23:40
    amiga4001
    Ok thanks ..is this also not possible with a wintel?
  • »08.07.08 - 18:39
