Modem on MorphOS 2.0
    RaMzey
    Posts: 7 from 2003/11/26
    Whether is in MorphOS 2.0 opportunity to connect the modem? Unfortunately the Internet only on dial-up. :-(
  • »05.07.08 - 13:40
    Jambalah
    Posts: 820 from 2008/3/30
    Well, there is a way to use Internet with dial up connection with MOS 2.0.
    Install Miami or Miami DX and make the right assign in user-startup.
    Then open Utilities:Editor and load DH0:Morphos/S/network-startup and modify the file putting a ";"
    at the command lines that haven't it.
    Configure Miami or Miami DX with the various setups (dialer,interface and so on).
    Re boot Pegasos and then go online with Miami.
    In this moment I'm using to send this post and it works...I'm using it with router and ADSL..
    And so is a little bit faster, but it's ok even for dial-up.
    I did it in this way because I didn't find anything to set up Internet with MOS itself and so..
    Bye
    [ Edited by Jambalah on 2008/7/5 20:10 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »05.07.08 - 20:08
    Jambalah
    I tested MiamiDX in a heavy way: result are strange.
    Connection is quite stable but sometimes could crash. Used with IBrowse 2.3 this happens more often.
    As told in another 3d, IB2.3 is not much stable (better 2.4). Sputnik goes much more better but other strange phenomena occour:
    sometime, opening a window, toolbar disappear and switchin from icons to list, nothing appears and the window seems empty.
    If you often use internet, it's better to install 2.0 in a partition and let 1.4.5 in another that you can use for Miami and dial up connection.
    The integrated TCP IP stack in MOS 2.0 is stable enough to change it.
    Although... MDX is much, much more ... fast! ;-) Hey, MOS Team, don't shoot me... It was only a test...:-)
    [ Edited by Jambalah on 2008/7/6 1:42 ]
    Pegasos II 1 ghz
  • »06.07.08 - 01:41
