Some MorphOS 2.0 questions..
    XzIt
    Posts: 250 from 2005/1/19
    btw, looking at readme for mixer tool, says it can operate any sound card connected to the system, but i seems to me that it only operats Pegasos Sound unit..
    Any setup or anything i have missed?
    just installed Livemixer, so i could get control of my Soundcard..
    X
  • »02.07.08 - 14:27
    Jambalah
    Posts: 820 from 2008/3/30
    Psss... Hey! Try "scube" with mouse.... ;-)
    Tested an "old" soundblaster and I heard no sound, too. But this is a no-proving test....
    By the way, very nice that when you click on a mp3, for example, on the titlebar appear the title song (scrolling if is too long) and "play/pause" and "stop" command! :-)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »02.07.08 - 16:40
    Jambalah
    @XzIt:
    I think you should go on MorphOS Preferences, then click on "audio" and try the last four modes (unit 0: 16 bit... and so on). They should be the right modes to hear the soundcard.... If I remember well, They were used for SB live! in the last AHI revision...
    Pegasos II 1 ghz
  • »02.07.08 - 16:48
    dake
    Posts: 204 from 2007/9/14
    kiero wrote:
    i already 'released' it yestarday. posted link to #morphos. anyway, it's on http://kiero.binaryriot.org/scube.lha
    Read included readme before trying it.
    Thanx its wonderfull, this is sooo COOOOL.
    Thanx for this wonderfull piece of work!!!!
    btw now i registred sucsessfully, soon i dont have to reboot every 2 hour:)
  • »02.07.08 - 16:59
    Posts: 1521 from 2003/2/24
    @XzIt
    That particular driver lacks support for new mixer API for reasons I dont know. In the future it will also use Mixer tool but for now you must use Livemixer :-/
  • »02.07.08 - 17:09
    Posts: 1090 from 2004/9/23
    > thx, but does not morphos 1.4.5 or 2.0 support > 1.gigabyte of ram???
    > can't get it to start, when 2x 512 meg.. help
    Two memory bars never work properly.
    Better only use one 1GB bar, which is even cheaper.
    Geit
  • »02.07.08 - 18:14
    Jambalah
    @ all:
    why don't you give an eye at www.amigazeux.com? ;-)
    There's a little app that I think you'll be glad to find...
    It's something about... windows transparency!!
    ....and IT ROCKS!!!!! :-)
    p.s: read always the read me.... Warning!!! It could become a drug :lol:
    Pegasos II 1 ghz
  • »02.07.08 - 19:46
