Install Help on MOS 1.4 on PRE APRIL Pegasos!
    magnetic
    Posts: 2129 from 2003/3/1
    Hello All
    I have a Pegasos board here with no April patch. The dreaded bus lockup machine. I cant get MOS 1.4 installed from the cd but I can get 1.3 going. Can someone please tell me how I can install 1.4 by hand? Thank you very much.
    magnetic
  • »24.09.03 - 04:45
    GMKai
    Posts: 257 from 2003/4/7
    you need boot.img and morphos/ on your hdd.
    copy the files in small packages to the hdd.
  • »24.09.03 - 04:55
    gunne
    Posts: 441 from 2003/2/25
    Hi magnetic
    Maybe stupid question, but have you tried with the cdrom/dvd connected as slave on IDE-bus 0 ?
    Best wishes, Gunne
  • »24.09.03 - 13:15
    magnetic
    Thanks for the help guys
    Gunne: I have it on Slave Primary.. Maybe I can try Master Secondary? I had 1.3 installed now, its all crazy
    GMKai: I need boot.img and morphos/ from 1.4 cd on my 1.3 install in order to boot from the cd?
    Am I copying in small packages becuase big xfers are what locks up bus?
    Why wont it just boot from the 1.4 CD?
    TIA
    magnetic
  • »24.09.03 - 17:34
    Posts: 1084 from 2003/3/24
    Why you didn't put the Harddisk in your April Pagasos and install MOS1.4 and then put the HD back into that non April Pegasos?!?
  • »24.09.03 - 18:20
    Coder
    Posts: 296 from 2003/3/5
    Hi Magnetic,
    First of all check here:
    http://www.morphos-news.de/beta2help/
    This guide will help you installing it. Now if you run into any probs could you describe them here or mail me them? I got the same board wich has 1.4 running on it and it did not cost me any trouble getting it installed. Don't worry we get this one working. That helpguide alone should do it. :-)
    Let me know.
    Coder
  • »24.09.03 - 18:30
    magnetic
    Thanks guys for your help.
    Coder: I'm afraid the guide isnt too helpful for this kind of thing (pre April board)
    I have 1.3 installed and working well. I try to boot from the 1.4 cd and it goes to the MOS splash screen, and appears to want to boot to MOS but it says my boot.img file is too old.. and instructs me to reboot using OF commands
    I reboot and type boot /pci/ide/cd boot.img
    and it goes to boot and then freezes in OF (IDE Lockup)
    What should I do? I guess I have to manually copy over files? How?
    TIA
    magnetic
  • »24.09.03 - 19:00
    gunne
    Hi again
    # I have it on Slave Primary.. Maybe I can try Master Secondary? I had 1.3 installed now, its all crazy
    Ok, I thought maybe you had it connected to the second channel, because if I remember right the most problems with non-aprilboards is when copying lot of data between channels and not between devices on the same channel.
    But I understand now from your posts that the problem is something else.
    Another question then :-), have you choosed FFS-INT ? Rember I had a lot of problem with this myself on a non-aprilboard, until I figured this out. If so try change to FFS-NOINT, or try SFS or PFS.
    You can also try delete everything on the system-partition, perhaps reformat the systempartition, (copy all data to another partition first), and then try boot from the cd again when the systempartition is clean and empty.
    Or try The Players suggestion, thats a good one :-)
    Best wishes, Gunne
  • »24.09.03 - 20:21
    Coder
    Hi Magnetic,
    That's strange. Did you try to boot with the 1.4 cd and the HD disconnected? See what it does there. Just only the cd. Try that first. Also wipe out the HD. Remove every partitions there are. Maybe do it in a PC. But like I said, try the cd only option first.
    Coder
  • »25.09.03 - 05:36
