PolyOrganizer
    cecilia
    Posts: 459 from 2003/8/30
    has anyone gotten this to work on their peg?
    I just downloaded it and it doesn't start. I searched here and no one seems to have mentioned it. (unless I spazzed out and did a search wrong).
    and I have been trying to update my MUI files and, yes, as far as i can tell I have ttengine.library installed properly. the demos seem to work, anyway.
    this PolyOrg didn't seem to come with any docs.
  • »22.01.05 - 16:19
    MaSC
    Posts: 63 from 2003/12/1
    Yup, install the ttengine.library version 7 from the news item on the main page (of morphzone).
  • »22.01.05 - 19:01
  • tom
    tom
    Posts: 149 from 2003/7/22
    I had the same problem, but now it starts and I can use it now and compare it with EverydayOrganiser (Whitch I've used for years without any problems, both on my Amiga and now on my Pegasos)
    Long live Morphos (I hope!!!!!)
    Cheers, Tom
  • »22.01.05 - 19:57
    DSLCC
    Posts: 246 from 2003/5/14
    Works good here! :) Nice looking program. All I did was copy ttengine.library into sys:libs and the program started right up.
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »22.01.05 - 20:23
    cecilia
    hmmm, well the lib is in the sys:libs
    and i made and saved that database file in the ENV:
    still no joy.
  • »22.01.05 - 21:20
    realstar
    Posts: 298 from 2003/2/24
    It's not starting for me either. I copied
    latest ttengine lib over and it loads for
    a second and then nothing appears, snoopium
    doesn't give any clues. I am guessing it
    could be an mui class it doesn't like.
  • »23.01.05 - 02:30
    cecilia
    that's why I found the lack of any doc annoying. it's always nice to know what version of whatever mui thingy the developer used to write his stuff on. :-(
  • »23.01.05 - 02:50
    Posts: 65 from 2003/2/10
    Have you tryed to look with snoopdos or snoopium ?
    N'cha, LorD
    http://www.lordfpx.com/
  • »23.01.05 - 07:12
    pegasosuser
    Posts: 138 from 2004/4/9
    I use this program a few day's and working good!
    I sal donate that program
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »23.01.05 - 09:25
    Polymere
    Posts: 7 from 2003/5/21
    Try to start it from a shell.
    You will have an error for sure.
    If not, send me an email I will send you the full debug version. It need serial debug or ramdebug.
    But by this way I will exactly know what is wrong on your setting.
    Why don't send me a mail instread of use MZ ??
    I don't look at all forum everytime...
    Regards
  • »23.01.05 - 11:30
    DedyAmigo
    Posts: 41 from 2003/7/19
    For me work it at a first time, but I would like to know about conversion data files from Digita Organizer? Is it possible?
    Sora for my English.
    Dedy
    http://amigo.bodli.net
    Powerbook G4/1.67GHz, MOS 3.17 reg
    Asus Zenbook UX32VD, Xubuntu 20.04
  • »23.01.05 - 11:40
    cecilia
    First, let me say thank you for making programs. such efforts are appreciated!
    I just now (sort of) tried to start it from a shell, but nothing seems to happen. Let me say that I'm not a programmer and can be a little stupid about the magic that you fellas do.
    I can make my own "magic" when doing my work, so I respect what you do.
    I wasn't worried yet about why it didn't seem to work. Plus, I wanted to know if others had tried this program. Sometimes this kind of thread is good "PR" for such programs.
    I did try SnoopDOS and it seems like there were few things that were wonky. One was that it seemed to be looking for the Cmanager lib.
    It also seems to expect TextEditor.mcc
    and I get a failure with
    ENV:CON.prefs
    I don't have that in ram so I'm confused (easy to do that actually) :-D
    anyway, I'll try to get as many of the things I see listed in Snoop and if it still doesn't work I'll send you an email.
    I had to do some snow shoveling today (1st blizzard of the season!!), so i was a bit delayed in my playing around... :-P
  • »23.01.05 - 21:56
    Posts: 62 from 2004/9/8
    PolyOrganizer is ok on my Peg2 G4...
    It works fine... All is OK :-P
    Good job Poly :-D
    PegasosII G4 512Mo 80Go ATI RADEON 9200SE....
    Yeah! The best it's MorphOS :)
  • »24.01.05 - 03:35
    matt3
    Posts: 764 from 2004/2/10
    Installed and ran fine here as well.
    Nice program!
    We have quite abit of snow here in Buffalo as well, NYC seemed to get
    plastered quite badly this time. I really don't like the snow, one or
    these days I'm going to head south. :-)
    Best Regards,
    Matt
  • »24.01.05 - 10:44
    realstar
    Well I solved the problem here, PolyOrganizer
    won't open on a 640x480 screen since the
    horizontal toolbar seems to require more space
    than that. I upped the resolution and it opens
    just fine now.
  • »24.01.05 - 11:16
    cecilia
    well, i have a screen res of 1024 x 768, so i don't think that's my issue.  :-D
    after using snoopDOS and adding a few more MUI files I think there seems to be something not right with my TTEngine install.
    I get the following "fails":
    ENV:ftcodepage
    ENV:CManager/AvoidasyncIO
    ENV:CManager/Avoidgenesis
    genesis.library
    and I don't have or use genesis, btw.
  • »24.01.05 - 13:29
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    I think that I found a bug (?) in PolyOrganizer. In fact the weeknumbers are wrong by one week...
    For example week 26 should be from monday 23rd june to sunday 29th june but in PolyOrganizer it is from monday 30th june to sunday 6th july.
    This seems to be, because the 1st week of this year is week 53 instead of 1.
    Is it just me, or could it be a bug?
    Regards
    Christoph
  • »20.05.08 - 02:41
    Posts: 1084 from 2003/3/24
    Everything's fine here with PolyOrganizer 1.07
  • »20.05.08 - 14:46
  • rms
    rms
    @ ThePlayer
    Very strange! Are you shure that the 1st week of 2008 is not WK 53 instead of WK 1.
    Please have a look at my attached screen grab, where you can see that the week numbers are wrong because of this week 53.
    And if your PolyOrganizer is correct (I mean WK 53 does not exist) then do you have an idea what that could come from?
    Regards
    Christoph
  • »21.05.08 - 03:36
  • rms
    rms
    Hi all,
    I just found out that there is a special setting to change the day when the first week of the year starts. In changing this resolves the problem.
    Sorry, but didn't notice this before.
    Regards
    Christoph
  • »21.05.08 - 03:55
