Icon alignment
    Posts: 16 from 2008/5/4
    How do I align icons to some grid in MorphOS?
  • »12.05.08 - 23:14
    Framiga
    Posts: 363 from 2003/7/11
    like you do with AmigaOS!
  • »13.05.08 - 10:52
    SoundSquare
    Posts: 1214 from 2004/12/1
    are we so bored ?
  • »13.05.08 - 11:44
    Looks like I'm asking a stupid question in your eyes. If it is so obvious to you can you please guide me instead? I cannot find a "clean up" or "snapshot" as I do in AmigaOS. There is no "align to grid" or equivalent? Seems to me MorphOS just saves the icon position when you drop the icon in a new spot.
  • »13.05.08 - 14:20
    mobydick
    Posts: 179 from 2004/2/26
    On the desktop: select an icon (icons), press RMB, choose "snapshot".
    But it is impossible to snapshot icon(s) in window.
    peguser.narod.ru
  • »13.05.08 - 17:36
    Korni
    Posts: 473 from 2006/2/23
    Both are possible and work here. "Snap/Align to grid" is on by default in Ambient. Maybe you have just an old version. Try the up-to-date Ambient here http://morphosambient.sourceforge.net/ (nightly builds).
    [ Edited by Korni on 2008/5/13 21:02 ]
  • »13.05.08 - 17:59
    On disk icons i only have the "information" and "format" options. Guess thats because the icons are snapshoted on every movement. There really isn't a "clean up" option somewhere? :/
    I use 1.4.5 PUP version
    [ Edited by sniken on 2008/5/13 21:05 ]
  • »13.05.08 - 18:04
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Unless you prefer sticking to mui3.9, i suggest you use a recent ambient version. 1.4.5 version probably had autosnapshot enabled and was rather limited anyway.
    Current versions allow to place icons on a 8x8 grid size, or at pixel precision if alt is pressed while dragging. Then you can just snapshot each icon (if autosnapshot setting is enabled, then you won't need that). And snapshotting icons in windows is also possible if you enable the "manual layout" option. Then icons won't be automatically sorted anymore.
  • »13.05.08 - 18:26
    Where can I find MUI4? When searching Google I find dead links to sasg.com website.
  • »13.05.08 - 18:45
    diezi7
    Posts: 167 from 2005/7/25
    Folowing the url below you can reach the latest MUI Beta
    http://www.stuntz.com/muibeta_20071223.lha
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »13.05.08 - 18:56
    Thanks. I'll have a go installing the two.
  • »13.05.08 - 18:58
    koan
    Posts: 303 from 2005/11/21
    Icons in windows are automatically laid out on a grid. If there is a way to affect this, to turn if off or to modify the grid spacing, I don't know what it is. I am using Ambient nightly build from October 2007.
    Disk icons and icons left out cannot be "cleaned up" or automatically arranged.
  • »13.05.08 - 20:25
    After installing mui4 MorphOS wont start normally anymore. I'm just presented with an empty MorphOSLog and nothing happens ebyond that.
    Edit: I got it working after manual install of MUI and Ambient from AmigaOS. Cheers.
    [ Edited by sniken on 2008/5/14 1:08 ]
  • »13.05.08 - 20:35
    Korni
    Set "autosort = false" in SYS:Prefs/Ambient/Advanced.conf.
  • »14.05.08 - 09:38
