TubeXX problem
    CountRaven
    Posts: 566 from 2007/12/10
    Hello folks, I just installed the great TubeXX software.
    I completed the installaiton and the configuration adding the paths for all the tools needed.
    I have also downloaded all the libraries + the RexMUI which are specified by the programm as important in order for it to run.
    But each time I try to go to a specific youTube link by pasting it or searching for a video, the programm would conenct to youTube, would show message that a title has found and would close (!) just before any result shown in the video list or just before the vidoe starts to play (if it is a specific video from a youtube link).
    In my console I would take those messages:
    +++ Error 15 in line 2: Function not found
    Command returned 10/15: Function not found
    Any ideas on what has gone wrong?
  • »26.04.08 - 16:03
    Framiga
    Posts: 363 from 2003/7/11
    download again the very latest RxMUI 42.7
    [ Edited by Framiga on 2008/4/26 19:23 ]
  • »26.04.08 - 18:17
    CountRaven
    it works fine now... thanks!!!!
  • »28.04.08 - 16:43
    koan
    Posts: 303 from 2005/11/21
    I had been using Flayer but decided to give this a try after seeing your post.
    Tubexx is really good! Thanks for posting.
    OK, some minor problems (it occasionally forgets some of my settings while I'm using it) and the download bar has a bit too much information. Otherwise an excellent work.
    I often do dev stuff in Linux but this is another reason why I should always boot MorphOS. Other irreplaceable software includes ATC, amrss and ShowGirls.
  • »30.04.08 - 00:03
