Which Software
    Posts: 1087 from 2003/3/24
    I have a question about this Picture who did it and which Software did he/she used?
  • »06.04.08 - 09:31
  • ASiegel
    Posts: 1397 from 2003/2/15
    Considering the heavy dithering of the terrain shader, I would assume that this was rendered using World Construction Set (WCS).
  • »06.04.08 - 10:12
    Are you sure WCS runs on MOS and do you know where i can get a Demo?
  • »07.04.08 - 18:43
    So you got WCS running, which version and where did you get it, and are there other WCS like Programms that runs on MOS/Peg?
  • »08.04.08 - 15:56
    Yomgui
    Posts: 348 from 2004/8/31
    Easy to answer: Blender !
    And now... next project!
  • »11.04.08 - 09:46
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi all,
    YES Blender of course :-)
  • »11.04.08 - 13:42
    Posts: 2217 from 2003/2/24
    At least World Construction Set 2.04 seems to work fine on Peg. Just tested rendering one frame of an example project :)
    I know this and Vista/Vista Pro on Amiga... Vista probably won't work. Blender has some landscape rendering options?
  • »11.04.08 - 14:32
    How do i use these Options in Blender?
    And anyone has an idea where i can get WCS used or new?
    Maybe WCS is Abondon Ware and i can get it on the Net?
  • »11.04.08 - 17:51
    luky-amiga wrote:
    I tried very old version World Construction Set 1.26... see my software index for graphics software MorphOS compatibility.
    So I will add WCS version 2.04 to database, thanks jPV for report.
    No problem. BTW you seem to miss Real 3D (3.5) from the database. It works fine and it's even freeware nowadays (used to be commercial).
  • »12.04.08 - 08:26
  • ASiegel
    @ ThePlayer
    I suggest you go the InnerWorld website and follow their tutorial.
    After downloading the InnerWorld extension from the same website, please also download the following file...
    http://yellowblue.free.fr/blender/IwInnerWorld.py
    It was kindly supplied by Yomgui who made sure that InnerWorld works with the MorphOS port of Blender. Just replace the file of the same name inside the InnerWorld archive with the one above.
    Beware that despite Yomgui's quick work on this, there might still be issues. If you encounter any, feel free to report those.
  • »12.04.08 - 19:42
    Yomgui
    This patched file will not be longer usefull for any futur releases.
    I've patched in blender directly to support some OpenGL features not supported by TGL.
    InnerWorld works fine with Blender 2.45 on MorphOS, except when you quit the program.... a crash may occure, but you can save your work before ;-)
    Anyway this can of picture can be easly done on MorphOS with some modern programs  8-)
    [ Edited by Yomgui on 2008/4/14 7:44 ]
  • »14.04.08 - 04:43
